Teh 'Going Home' thread...
  • Replies 74
Hehehe - I know what you mean - they're too many great cars to have and not enough time, money and garage space to own them all! :rolleyes: Only option is to buy, drive and sell often. Only trouble is though, the paper work is a right pain in the butt - especially getting landlords to sign parking permission slips :P
...hope she makes 220-230awkw with the new HKS SA CPU, the old F-Con V was too restrictive.
Justin you coming tomorrow?
On the dyno today she made [email protected] all the way to 7000rpm, no boost drop. A bit more than what the old CPU was tuned at. But still short of running 1.5bars, due to the injectors cutting out around 4000rpm for a split second. Not sure what the problem is, we know it ain't the CPU or the sensors. Back on the dyno she goes on Monday.
edit: I think I found the problem...stupid me!
Can`t you just give the evo to rezz as a going away present? :)
He wishes...a limited production car! :)
Just hand it over mate...
You KNOW the first thing I'd do is karate kick those stock mirrors off, then karate chop that back wing in half and sell it on Yahoo, then get some decent black rims and some decent black aero mirrors :)
Which is why you should buy your own :), I like the stock look :)
Yeah time to move on.... it's like being a kid in a candy shop here though, so I think 1 year max before selling and buying smething different!
Justin, how about an RS200 with HKS bolt on turbo kit or buy one with a turbo already fitted. Still RWD, newish which what you really want right...avoid the headaches of things falling of old cars.
Yeah right, I just want something newer... and not a whale! This is the problem, I don't want to go the extra for an R34 because for that money I'd prefer an FD3S, which leaves me with a late model R33. I just don't dig the whales... and R32s are too old in Japan terms as Ikeri told me last Sunday... *sniff* :)
Dave, you can't comment all your cars are new...the R32s are getting long in the tooth.
Justin is keen on the Evo, I believe because they are newer, 4WD and being able to extract 250awkw not rwkw from a factory car with very little money. Which would be more than sufficent for anyone on the street . The Evo is pretty good value when you only have to spend money basically on a subcom and EBC to achieve this! Course one would change the airfilter and exhaust. Compared to extracting power out of Skyline's factory setup with a ceramic turbo achilies heal. New turbo, new I/C, new oil cooler, new management, EBC, new exhaust = big $$$.
Yeah... how'd you know I had only 1 friend in the whole universe?
Batsuman is a loner...how could he hide his identity if everyone knew who he was in Japan? However Batsuman has many admirers. As his butler and driver, I've already hire someone trustworthy to fill my place, however this person does not have an Evo which is why Batsuman needs to built a new Evomobile Spec II :(. The GT-Rezz is still under development.
OK, the secrets out...Justin (a.k.a Batsuman / a.k.a Rezz) has decided to forego the Evo for something more in-keeping with his tastes. The GT-Rezz has run into technical difficulties (due a national shortage of duct tape, without which essential body mods cannot be completed) and this has left but one choice. So, without further pre-amble, I give you the Batsumobile (Beatmobile :D)...
See here in these exclusive test shots:
660cc of Raw power :D
And remember folkes...you saw it here first....on the SAU :D
:(:D:rofl::D:rofl::D:):D
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
