Ive picked up my R32 GTR, absolutely great condition. However, after a descent run (but not always, its happened twice so far) the car will not rev past 2600 rpm, power completely cuts out as if hitting redline. Car works fine normally and this has only happened twice. Cant get into hypertune or racepace till new year so wondering if anyone had any possible causes?
My temp gauge usually shows a temp of 83 degrees... is this normal or high?
https://www.sau.com.au/forums/topic/58775-r32-gtr-power-cuts-out2600rpm/
When I first picked up my SR20 180SX a few years back I found an RPM 'window' from 3000 to 5000 where power all but died. It turned out to be a fuel pump that was on its last legs and pumping at 40% capacity. After replacing it, the car run beautifully and power delivery was restored to normal.
This fuel problem occurred 90% of the time. The frequency of your problem sounds a bit more like its electrical, but if you run short of ideas, perhaps get your pump tested?
Mark
He said it cuts out completely
']more likely than not, its your intercooler piping. check all the clamps to make sure they are secure. also check that there are no hoses that are split.
How can a small leak do just that?
Please explain
Zahos: i blew the clamp off my cooler piping and it would not accelrate past something similar to GTSpec's rpm. It really does feel like hitting rev limiter. The fact that air was escaping and not going into the motor will make it run like shit.
did the pipe blow off completely or was it just enough to leak?
Coz I have blown my cooler pipes right off before, and I couldn't even drive the prick.
I have also had leaks, but it only made it hessitate (yes it did run like complete crap, but I could rev it well past 2600 rpm)
If his car drives fine most of the time, and twice (twice is a key word here), it has not revved past 2600 rpm, then it is most likely some sort of sensor crapping itself / not connected properly.
AFM is the first thing that comes to mind. It could be something else, but I dont want to be a keyboard tuner and say exactly what it was without looking at it.
well i dont know exactly what his problem could be but you would wanna hope it was something minor like the pipe. Its happened to my GTR, and my friends Soarer, Supra, AND Sti. Once it happend with just the leak without the pipe coming off and it wasnt able to rev very high at all.....when the boost hits.
Your ECU is running in closed loop, judging by what you describe. Usually caused by no signal from an AFM. Very common on BNR32's. Try swapping them out one at a time for a known good AFM. Then explore other possibilities.
Hi thanks for the replies. This problem has been occuring more frequently over the past few days. To elaborate, when the problem occurs, it will not rev past 2600 exactly so i am pretty sure it is a safe mode the comp is going to.
Also, just before the problem occurs, i can feel the power of the car is a little lethargic and suddenly its back to normal for a few secs then lethargic again and then into safe mode. I had a look at the airflow meter and the wirings not flash. Gonna see if i can secure the wires and see how it goes for the time being.
With airflow meters, if one of mine was shot, wouldnt it always run bad??
Have you given the ECU fault codes a look yet?
There's instructions on how to display and interpret them, I can't find them right now, have a search for yourself or hopefully someone else can point you in the right direction. Doing thsi first COULD save you a lot of time.
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
