Hey guys,
Over here in NZ we're allowed the luxury of radar detectors (and believe me they are a luxury - even if you're not the type inclined to speed they do give a little extra piece of mind). I was told they are completely illegal in Aus, what's the penalty for being caught with one??
https://www.sau.com.au/forums/topic/58989-naughty-ol-radar-detectors/
My Road Angel is one of my best investments yet.
As I understand it, it's avoided being banned by the police because it's a "hazard/blackspot warning" device.
The logic- speed/red light cameras are *only* placed at accident blackspots (not places where they generate the most revenue right) so the Angel is just another road safety tool.
Aside from giving advance warning of accident blackspots (aka speed/red light camera sites) it also shows:
■ School safety zone warnings during school hours
■ Railway crossings
■ Country town entrances where speeds change (from 100 to 60 kays)
■ Point to point speed safety cameras
■ Multanova safety camera areas in Perth
? School safety zone warnings during school hours
? Railway crossings
? Country town entrances where speeds change (from 100 to 60 kays)
? Point to point speed safety cameras
? Multanova safety camera areas in Perth
how much do these road angels cost?
They are perfectly legal to use and own, been pulled over many a time with mine up.
They also pick up road works, crew signals and emergency vehicle signals.
They should be allowed in other states if u ask me as they are advising u of upcoming dangers.
Politicians lick nuts
PS if you buy one for $300 you are wasting your money i wouldnt spend under 800, that or buy a second hand top of the range one.
They are totally legal in WA. However, if they really want to ping you for something they will get you for obstruction of vision. I have been warned on this so now when i get pulled over I quickly remove it for peace of mind. Also, I feel it gives the cops and extra reason to try and get you for something else seeing as it gives them the notion that "this guy must speed alot and thats why hes got a radar detector etc etc.
Word of advice: try not to drop the detectors. Mine still works ( as in beeps etc) but i have lost the visual side of things.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
