Ok this is the thread we've all been talking about.
Please post your intentions and what windows you want done; ie if you want doors only or doors and quarters or rear windscreen as well. Also note if you have a 4 door or 2 door. Also your preferred time frame.
I think that's it.
Don't whore the thread or post maybe if you're not that likely. It will probably be easier to add people than to come at a disappointment ok.
EDIT******
Ok cost will most likely be $160 for a 2 door and $180 for a 4 door.
$60 to remove. This is standard price as he will not budge because it's a shit of a job. I believe him.
Deadline is 10 January for confirmations however you don't have to get them actually done until you are ready.
It's a cash job so don't turn up with your mumma's dentures expecting a trade.
I will be posting and pming around the 10th so until then, drive safe peoples. I mean it.
******FURTHER EDIT.
This is my email details.
sarpi @ punkass.com
Please send in the following format:
Username:
Car 1:
Car 2:
Real Name:
email if different from the one you're sending from:
Contact numbers:
*********************FINAL EDIT
The group buy has now finished. Those of you with codes, ring up and book your time, quite a number of people with codes are yet to get their tinting done.
https://www.sau.com.au/forums/topic/58990-nsw-only-window-tinting/
  • Replies 154
nice one Adam. Good to see someone step up for the organising.
I would be interested (of course pending pricing). But can only do it Feb or later (in Japan till end of Jan, and car to be complied early Feb). I want tint for my GTR and probably the soarer too.
Richard
Definately interested. R32 GT-R (coupe, obviously). Any time: the sooner, the better.
I suggest we try and sought out a coupon system like the last one, so people can purchase a coupon that is valid for X weeks or months.
LW.
I'm looking to firm up numbers very early in january and then I will be getting a price.
I think a few people posted in the old window tinting group buy thread what they paid in the end.
Yeah good idea eh B-Man?!
Cool.
I've an idea we are looking at around $160 for all windows on a 2 door, $180 for a 4 door. Probably cost around $60 to remove. This is an early indication only. I have more work to do in this regard.
Will confirm prices in early January.
Ok I've cross-checked prices now and this is a very good deal.
Can you tell it's my last day at work today?
The guy is on holidays until the 10th at which point I will be confirming numbers and price although price looks good as is.
So post away people. I'll be back here in January.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
