  • Replies 86
Just spoke with ivan @ speedworks. He's more than happy for you guys to come to him for $50/person to have a power run on his dyno. Depending on numbers, might be able to get a couple of runs. I'd be pretty interested to see what numbers my car is up to now. I was up to 160HP @ wheels just after fitting an exhaust (stock airbox still etc). I'm sure it'll be over 200HP @ wheels.
Rob
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89527
Guest Autoworx
Streetforce in Wangara have just got a new Dyno and only charge $55 inc GST for a power run including printout. They are located next to me a Unit 3/38 Baretta Rd. They also manufacture and fit front mount intercoolers, 3" mandrel exhausts, air filters, bleed valves etc. They have already fitted heaps of mods to cars I've sold to customers so I can vouch for their price and quality.
Call Jason on 9408 3018 for quotes or pop in. You can check out our Skylines in stock & body kits at the same time
Paul
Autoworx
www.perthcars.com
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89535
mid december mid december!
stuff any later off :uh-huh:
whats wrong with mackas car? mid december macka - be ready :D
dunno what they usually cost, but do they tweak it a bit? or is a power-run just a read-out? if it's just a read-out, I'd be inclined to pay 20 or 30 as greg said
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89555
Ok, I'll talk to ivan again. If you want $30/car we are going to need to get a fair amount of people. When I rang PSI (about 6 months ago) to get a price on a dyno run (ie: run car with stock everything and then fit exhaust and run car again) I got quoted $100+ for the dyno time.
Rob
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89642
Hey Miko!
Last time you helped organise the dyno day it only cost about $25 at PSI. Maybe you could have a chat to Brett?
I think it would be good to use the PSI dyno again as most of us used this one last time. And as we all know the dyno is really best used as a refference (before and after) not as an absolute.
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89742
Yu[p,
I'm in the same state of mind as everyone else here... $50 is over the top, however a big thanks has to go to you for at least trying organise something like this! GREAT IDEA! Hey Summoner, the last Rollaboyz dyno day that i saw your car at when youwere tlaking to my bro i think he said it was only $30 that was at Melville i think???
Yeah i will be speaking to Brett@PSI sometime this week and should be able to get us a nice deal for a dyno day.... i guess the more numbers the better kinda thing... will this be on a saturday or a sunday guys?
Also PSI got their new dyno about 4 weeks ago! VERY NICE!!
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89783
any 2 wheel dyno is out if any of the GTR boys and girls want to come.
so that doesn't leave much of an option.
PSI's is 4wd theres a couple more around but i'm not sure where.
$100 at PSI is for tuning not just a power run.
power runs are usually the $50 mark.
Dyno days tend to be about $30 per car. but u need decent numbers atleast 15-20 cars.
adam nothing wrong with using PSI for a dyno day.
work on my car has been fine no problems others we know the story. i just don't go there anymore because of his stupid wife. Accused me of trying to ruin there business when they were broken into and she tried to get Kylie fired from her job.
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89911
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
