Searching for a well looked after r32 gts-t
  • Minimul modifications perferred
  • Victorian sellers
  • 2 door
  • Manual trans
The car must be in Melbourne and available for us to check it out before any money is put down.
1991-93 much preferred, but will look at 89's and 90's too!
A car with no accident repair, no broken interior bits etc will really get our attention - we will pay for quality
Please do not hesitate to PM, email me at [email protected], or call my mobile on 0416 367 799.
https://www.sau.com.au/forums/topic/59183-wtb-r32-gts-t/
Hey rrrage, incase you havnt searched through these sites for an R32 GTS-t, here ya go:
www.melbournetradingpost.com.au
www.carsales.com.au
www.carpoint.com.au
(you've probably been visiting these sites, but id thought id put in some input).....any specific transmission type?
heres one i found on carsales: http://www.carsales.com.au/pls/carsales/!c...rch_distance=25
Good choice on car :( ....i will be looking for an R32 GTS-t as a 1st car aswell in about a year or so, cant wait! Beautiful cars in the flesh.
Good luck with your search :thumbsup:
Steve.
https://www.sau.com.au/forums/topic/59183-wtb-r32-gts-t/#findComment-1130237
Hi,
I have a Clean R32 GTST
Stock rims and suspension.
3" exhaust./ POd filter.
Blue with purple pearl paint job.
New Slotted disc, and pads.
New Battery
New clutch.
Alarm, Imob with all the fruit.
92 model.
Manual
PM if your interested
https://www.sau.com.au/forums/topic/59183-wtb-r32-gts-t/#findComment-1142796
1989 R32 GTS-T Type-M (RB20DET – Silver Top)
5 Speed Manual
Black
88889Km's
A.C.T. Registration until September 2005
Only mods are:
Trust Air Pod
Rear Strut Bar
Centre Console being painted grey
Sorry it's not located in Victoria, if you interested go to the link:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=59983
PM or email me if you are interested
https://www.sau.com.au/forums/topic/59183-wtb-r32-gts-t/#findComment-1146888
  • 4 weeks later...
I've got a 4 door GTS-t in immaculate condition with 55km, manual, stock exhuast, tyres, interior, very straight and very smooth to drive. Qld and 4 door, let me know when you are ready for a trip up here and give up on finding a 2 door in stock std trim.
https://www.sau.com.au/forums/topic/59183-wtb-r32-gts-t/#findComment-1203886
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
