Hi ppls.
I've ran in to an injector problem and have had to get another set cleaned up and the old set that are stuffed ripped out.
I am after a place in SA that do a good job for a decent price.
Let me know if you know of some one and have had experience with them.
Hi ppls.
CARBURETER SALES & SERVICE (S.A.)
6 Little Rundle St Kent Town 5067 (08) 8132 1465
Fax Kent Town 5067 (08) 8363 6373
I think his name is John, cleaned my GTR injectors and got them flowing within 2% of eachother. He gave the terminals a clean as well, made sure everything was 100%
From memory it cost me less than $150, I think it was about $130
:) Chris
got my injectors cleaned at sprints fuel and carburettors
on bridge rd, next to the hyundai car dealer.
Cost me about $120 including new o-rings.
hope this helps.
Shaun
had the car in tilbrooks cause the car was leaning out.
Thought it was the fuel pump, but replaced that and
still found that i had the same problem. Then borrowed
a standard set of injectors from tillbrooks and got them
cleaned and the car still ran lean when i put them in.
So they think my computer has been chipped, but my
car was stock when i bought it so i have a problem
that no one can figure out.
That's why i got my injectors cleaned.
the fuel pressure reg is now been squished to hold pressure.
this brought the fuel map down .3. From 12.3 to 12, tilbrooks
said it wasn't the problem, its got everyone scratching their heads.
if i don't sell the car i will be putting an ajustable fuel pressure reg
on the car, will see if this makes a difference. I will also be checking
the computer for a chip. :P
i had my vl turbo ones done at mildren race engineering.
they are a bit more expensive than some places (because they charge extra for o-rings or new pintle caps) but they did the best out of the 3 places i've been to.
i had two other sets for my previous cars cleaned at other places (one near city dismantlers and one in lonsdale) and both times after the clean the cars were harder and required more cranking to start, which is apparently an indication of leaking injectors (and the puff of black smoke one of them blew after every startup confirms that).
I went through these guys to flow test, clean and re-flow test some injectors I might put into my FJ20, I requested a before and after so I could see the difference of what the clean did, they also replaced the pintle bits and o-rings and another rubber that sits near the top of the injector in the price, $25 per injector, extra if you need them to take them out of the fuel rail for you.
The only thing that disappointed me was the fact that they couldn't tell me how many cc/min the injectors are good for! Which to me seems a pretty basic thing, they do however give you details on how fast it flows a certain amount of volume, so from that you can work out the approx cc/min of the injectors based on the pressure they feed them at.
It's $20 per injector if you only want them cleaned and flow tested.
Cheers,
fj910
it was worth the money for the peace of mind i suppose, turns out they werent badly blocked or anything. the spray pattern is just hand drawn so in my case it didnt show any difference. however the flow rates were all the same after and they did vary a bit before.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
