hey guys. i got a Sony FM/CD Player the only prob is the tuner dun go pass 90. so i guess thats that jap prob ha
anyhow it says DSP/TV Controler..
oki any one knws wat the TV Controler part do and how ?
its a
Sony CDX-C6000 came with a sony equalizer...
any idea how i can get the tuner to go pass 90, cos i dun wana change the system. well dun wana buy a whole new one. cos it has this small thing fixed just below the steering whell wheel where i can change the things on the system
anyone?
https://www.sau.com.au/forums/topic/59281-samll-freq-prob/
Digital Sound Processor/TV controller just means you can plug it into a tv or dsp unit and you can control it from the HU.
There are things you can stick between the antenna which will change the frequency range over to australia - I'm suprised they didn't do that at compliance. Are you sure you ain't getting 104.1 on say 89.1 or something? I've seen a lot of cars do that.
If it ain't there and you don't wanna switch the HU over just buy one - I don't know what they're called (FM modulator maybe?) but they will get it higher in the frequency range where aussie radio is. The only downside is your FM freq numbers in the HU will still only read up to 90 so you'll just have to mentally adjust to the range the modulator is changing to.
https://www.sau.com.au/forums/topic/59281-samll-freq-prob/#findComment-1131469
Go to any half-decent car audio shop and ask for an FM Modulator for your car. It'll allow you to tune into local stations. It's not as good as a deck that can handle local frequencies, but will work as good.
https://www.sau.com.au/forums/topic/59281-samll-freq-prob/#findComment-1131611
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
