hey guys!
i recently took my tires off, and found that the inside of both my front tires are worn down pretty bad. i'm guessing its due to my car being dumped, causing the wheels to be on an angle. what do i need to get this fixed? is there a place you guys can reccommend me? i'm a noob on this, so any info and advice will help me get the ball rolling. appreicate it :)
https://www.sau.com.au/forums/topic/59496-tires-worn-out/
hey guys!
You probably just need a wheel alignment mate. Ask your local tyre dealer.
https://www.sau.com.au/forums/topic/59496-tires-worn-out/#findComment-1134991
If you're driving around daily with seriously dumped suspension, your negative camber will obviously wear the insides of your tires b4 the outer tire... so a wheel alignment isnt going to solve the problem. It's something you have to expect if you run lots of negative camber to fit the wheel/tire under your guards when your car has very low suspension. Looks good but only get half the use out of your tires ! Hope they're not 19's :D
https://www.sau.com.au/forums/topic/59496-tires-worn-out/#findComment-1135143
yeah, i have 17"s on my wheels.
where can i get an adjustable camber kit? and get it installed aswell?
how do i correct the -ve camber? i also doubt its my wheel alignment...
Skylines don't have much adjustment when it comes to camber. Get adj. upper or lower control arm bushes and get it all aligned.
Simple fix.
https://www.sau.com.au/forums/topic/59496-tires-worn-out/#findComment-1136067
Hi mate,
I got a mate that used to work at repco to contact nolothane which made the adjustable control arm bushes up for me.
Make sure the mechanic puts em on properly. I have 18" and my front tyres are stuffed now.
I then took my car to a place called Trackright in Dandenong and they fixed it up for me, they also do wheel alignments.
Hope everything goes well
take it easy
Mark
https://www.sau.com.au/forums/topic/59496-tires-worn-out/#findComment-1136449
Go to Centreline for a good wheel alignment (thomastown).. they do all suspension mods/installations etc including whiteline kits.. gave me a cheaper quote than listed on the whiteline website.
9469-2914
I definately do not recommend B.J. at Preston due to more than one bad experience on 3 different cars. :
https://www.sau.com.au/forums/topic/59496-tires-worn-out/#findComment-1136644
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
