well i finally got my gtr, she started straight away and runs pretyt good, although i havnt revd it over 4000rpm. (not untill i service it etc)
anyways, a few things, 1 of which makes me very worried.
the under carrage has some damage which looks pretty serious, it looks like they lifted it with a fork lift. 1 of the bars on the frame is pretty badly crushed, and the other side doesnt look too good.
Ill take pictures of it toomorw and post em up.
question is, can it be fixed legally? will it cost me **** loads? i was all happy my car came, then i looked underneith and it killed the smile :P i think it was done while they steam cleaned it.
also, the back diff is making a huge clunking noise, esepcally when i turn right. is the diff locked? i wanna unlock it if it is.
also my boost gauge was stolen.
i knew there was a risk in importing, so i dont need to hear that.
steve
https://www.sau.com.au/forums/topic/59855-got-my-gtr/
  • Replies 48
The rails do bend easily
Mine were perfect until the licensing inspector decided to jack the car up to check the wheel
bearings.
Couple of nice big dents in there now!
Thats nasty damage.
Looks fixable though as the rear of the rail sleaves into the front.
Possibly dolly the front section and replace the rear.
Then heaps of underbody tar j/k
Do you think it happened during shipping?
https://www.sau.com.au/forums/topic/59855-got-my-gtr/#findComment-1140868
there once was a time when you could inspect your car before it went to quarantine/ establishing wether or not it(damage) happened before or after it got of the ship? coz if it was on this side of things i would be asking for compensation! guess thats why they dont do it no more? came very close to the fuel lines there mate
https://www.sau.com.au/forums/topic/59855-got-my-gtr/#findComment-1141428
Hard to tell on the photos but it does look like its been like that for a while.
Everything fixable just depends how deep your pockets are.
If chassis rails can be repaired on vintage cars and complete sections cut-out and replaced
why cant yours be fixed?
Go and see some body repair shops and get some quotes its the only way you'll know for sure.
https://www.sau.com.au/forums/topic/59855-got-my-gtr/#findComment-1141503
dont stress....thats an easy job......heres how i did mine.....whoever jacked mine up had the sense to stop once is started fu(king it too much.....first you unspot the rail.....then planish it true again using a nice big lump of steel and a panel hammer(i use a 30cm length of railroad track i have) then clean all the sealer/deadner off the floorpan then reshape the floor pan by whacking it with a heavy hammer using a lump of wood to insulate it.....then give it a tune up with a hammer and dolly using the now straight rail as a guide to what the shape should be.....respot weld the rail on and reapply the factory seam sealers(not using that black tar sh1t that everyone use's.....if i catch anyone using that....you get castrated!)using the correct spatter gun and replicate the underbody colour and dress up the floor pan inside the vehicle and the job is done
https://www.sau.com.au/forums/topic/59855-got-my-gtr/#findComment-1142020
I agree with ylwgtr2....any competant panel beater should be able to repair that without problems, but of course there will always be a cost. Perth people should be able to make some recommendations, but get at least a few quotes.
If the damage was done by a forklift there should be other signs....eg 'flattening' of the the sill pinch weld, but there's not enough detail in the photos's to tell. But I agree with someone else's comment that the damage looks 'old'.
https://www.sau.com.au/forums/topic/59855-got-my-gtr/#findComment-1142077
thanx heaps ylwgtr2, reading that makes me feel a lot better.
i had a closer look at it, and the damage wasnt done from a forklift. the damage goes across one side. it looks like it was beached (or what ever you call it)
ill try to take some more pics. i dont think theyll be able flatten this one out, its squashed down too much.
thanx again dude.
steve
https://www.sau.com.au/forums/topic/59855-got-my-gtr/#findComment-1142100
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
