Hey Guys,
I'm in Japan at the moment and have found a second hand parts store that has a Power FC for my car (BNR32) for around 600 dollars with controller.
I have a few questions -
1. the serial number is PFC RB26 9605-0387. Is there any way of telling how old it is? it looks to be in very good condition...
2. in my very poor japanese / english translations, the guy said that there was no maps on it... my question is- do all PFCs have a 'base map' that cannot be erased? I don't want to buy it and find that it has to be programmed from scratch.
Thanks for your help in advance!
BTW - i was like a kid in a candy store!! If anyone ever visits Japan, make sure you find an 'Up Garage'!!
Hi Marcus,
I always thought that the FC came with base maps. - Inless its you'r translation :wassup:
If the maps were deleted using the PFC laptop software this wouldn't save on to the FC it self could it ? Maby thats whats been done :uhh: Ask the bloke if you can install it into another car their and try it, or is that not possible ?
:D
Jun
And grab me a cheap hand controller for the R33 GTSt mate :rofl:
I understood the base maps were always there, but be cautious of the PFC being password locked. Good idea to get them to demonstrate if possible.
Cameron / Geoff: they can't demonstrate as there are no 32GTRs there... the rough translation of the characters on the box is 'signal / data check before use'!!!
don't think it is password locked...
might just hedge my bets and get it and see...
my advice would be to just but a brand new one. it's not worth as much if it's not the latest revision. The early ones can't be used with FC logit and the later ones apparently have some firmware upgrades too. unfortunately the only way to check is to plug it into to a 32 or 33 GTR and see what version it is. I say just buy a new one, unless you're confident of what it is.
Richard
Marcus, cheers mate. Anywhere up to $150 or so will be fine....and maybe a long cable, and don't forget to add some extra for your trouble, like a carton of cold ones :D
It should be OK if it isn't password locked, so then you can still tune it at least. Highly recommend driving as little as possible/very gently if using the base map.
Geoff: went to the Up Garage again today, seems as though all the hand controllers are sold with the respective PFCs... sorry about that.
B1: the Up Garage I went to is... either the Kawasaki or Hiratsuka Tokkaido store... not sure which one but know how to get there. It isn't very big, but main reason I went there because it is on my g/f's house train line. There isn't a heap of stuff there.
Suspension isn't a heap cheaper than second hand stuff you can get from people off the forums, plus it is damn heavy to ship over.
I decided that the plastic has taken enough of a beating (bought a EVC-R today), so will get a new Power FC from Nengun when I get back and have some $$ :Oops:
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
