Hi Guys
My mate has just landed a few thousand hybrid intercoolers.
600mm x 300mm x 76mm and the
450mm x 300mm x 76mm.
These coolers are from the hybrid factory so they are exactly the same design as the original hybrid coolers. The specs you see on those intercooler also applies here..
while stocks last I have the limited edition version - sold out
Here are the specs
Attrictive polished aluminum look
3" inlet and 3" outlet pipes for high flow
Low pressure drop 0.2psi at 15psi of boost
80 psi for up to 800 horses
Made by lightweight but strong material. Same Structure and material used as famous "Hibrid" Intercooler. Weight ~8kg
All coolers have been Pressure tested.
15 bars core design. For more efficient air flow over the older 16 bar design.
2 sizes
Size: 600mm x 300mm x 76mm
up to 5 buyer: $330
5 to 10: $300
10+: $295
Size: 450mm x 300mm x 76mm
NEW PRICES
up to 5 buyer: $325
5 to 10: $295
10+: $290
postage: ~$25 to the east side of australia and $30 to the west.
As seen in the picture the cardboard box has polystyrene strips to protect the fins from transport damage. The cardboard box is even double up in places for extra strength.
Payment must be by Direct Deposit.
Local Pickup is available. Save postage
If you have doubt about buying from this group buy do a search for other groups buys with my name. Im sure you will find out quickly Im an honest bloke . Also if for some rare reason I can't get the parts and you have already transferred money to my account your money will be transfered back to your account straight away!!
Piping will be available soon for this intercooler. Still don't know the ETA of when the pipes will arrive in Australia.
https://www.sau.com.au/forums/topic/60147-hybrid-intercoolers-group-buy-no-2/
what do u mean limited edition
Well on the Tag it has "Hybrid super intercooler limited edition". I will post up a picture tomorrow.
Now I know you want to know what is good about these coolers compared to the normal hybrid coolers. Well That question still needs to be answered - I dont know. I think it is suppose to have better cooling properties but I'm not sure.
ok , im in for 1 of these , however , some stuff needs to be clear up here for every 1
- this is a group buy, with different amounts according to how many buyers. if i pay today for XXX amount and then 25 other people buy them , then what price will i be paying. As you posted above , derlivery is same day or 2- 3 days .... how does that work ?
- is there an end date?
- why is the pic of the hybrid plate , look like the cooler is second hand ?
Usually how I work this is like so
1) I monitor the groups buy on a daily basis. If it is slow (takes more than weeks for to get 5 people) then I notify everyone to see if they are still in. If the 5 people are still in then I will go to my suppiers place and pickup and deliver the parts. If less than five people, well people usually want to wait. Otherwise I can go down and get a cooler for the < 5 cooler price.
2) If lots of people are interested then I will just wait till 10 or greater. If there are 15, 20 buyers then I will haggle my supplier for a better price.
3) I know how people get worried with money so I try to make money hand over the last thing on the list so I can make the transfer a quick as possible.
Just got word from my supplier the coolers with the limited edition plaq are all sold out. gee that makes me mad!!!! Sorry guys. But the piping will be due in a month woohoo!!! s13 R32 R33 will post up thread
The other coolers he has are from the hybrid factory but without the plaq and hybrid badge. I will go over his place and try to find out the difference between them.
The 2 guys that have to limited edition cooler shipping to your place from the last group buy are very lucky.
not happy.
no the cooler is not second hand. It just looks like that from the flash. I would post up one without flash but it is not worth it now.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
