Hey guys I have just had price given to me for a new turbo and power fc for $3,500
what do ppl think of this price the turbo is a gt 35/40 garret. The guys also said there is a much better computer to use now. So all in all what do ppl think.
https://www.sau.com.au/forums/topic/60542-new-turbo/
The GT3540 is a very nice turbo, and quite a good price. The problem I have read about is they only come with a 1.06 exhaust housing which is way too big for an RB25DET (more suitable for a rotary and RB30 and XR6T (the XR6T is a 3540 but with a smaller comp cover, .50 instead of .70 like you buy from Garrett).
You can get the turbo modified to a .82 exhaust housing which is alot more friendly and should start to make decent boost around 3500rpm. Do not go for any of the .6x sized exhaust housings as these are too violent coming onto boost and you will just wheelspin everywhere.
A guy off these forums fitted one on his RB25DET by the name of NisJet, it made 210rwkw on 12psi. His car has 3 inch exhaust, intercooler, power fc, fuel pump.
--- EDIT ---
Do a search for GT3540 and you will see a few people that have run them. Most that keep the large 1.06 housing have forged internals and need to rev the car to 8000rpm to make good power out of it. Also does that price include a new manifold? I think it was Roy on these forums a while ago wrote you need spacer plates to put it on the stock manifold or else the comp cover will hit, and it generates heat spots and warps the stock manifold.
https://www.sau.com.au/forums/topic/60542-new-turbo/#findComment-1148861
I would always stick to the big jap brands - Zoom or HPI did a review of a range of A/M turbos a while ago, and it was proven that the JAP brands kick asre over the 'copy' series that you can get.
Makes sense to get something that has been specifically developed for your application, you can get some real bargains second hand. Try http://www.tuneagent.com/index.aspx and http://www.upimports.com.au/UPI_Parts/ as for starters.
https://www.sau.com.au/forums/topic/60542-new-turbo/#findComment-1148963
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
