I haven't got a copy but I'd guess it's a "New Car", well it's probably the Gorgeous GTR Pearl Princess youve been driving. Congrats Jayce!
EDIT : Hang on! It could be the Golden Girl?
C'mon - Tell your mates or it never happend.
That's it I'm going to the news agents to find out......
You forget....I know where you live...and I bet you have a copy or ten. Expect a visit...lol
Erica....put on the jug willya honey, Ill be about 20..hehehe
Ah...nothing like building up the suspense levels...
Hey Richard, It's Erica, Coffee's on and I've got chocolate bickies too so come on over and bask in the ambiance that is GTR 94V (PS we have the magazine here and Jayce is grinning like a cheshire cat!)
Jeez they must be running out of good cars to show, reckon they could've found a V8 ute or something, bl00dy old skyline??????????
Nah, just kiddin', always is a tidy unit yours, congrats, and choccy bickies, bribery, bet it works.
You realise this is just a start.
I'll have to get a copy 2moro.
Damn E, you've got the hottest coffee in town girl and bickies to die for , MMMmmm! Very nice Thankyou.:aroused:
BTW it's not the first time you caught Jayce with Magazine and a :cheers: on his face is it!!!
Bahahaha
