Ouch...after that comment i feel a sharp pain in my never regions:)  Could it be from a cheap kick to the boss cags:)
LOL...to an extent your right. I should have insulated the high mount a long time ago, but there is a story behind why it wasnt done:( ...but anyway, whats done is done:)
I may just wear my injury with pride, and as a reminder to myself :)
hahaha your a funny bugger!
  • Replies 68
full carbon fiber bodykit, then the problem will be gone, and your car will be lighter! :headspin:
someone say bandaid? we're just in the process of importing this silvia that sports a massive band-aid...
rock candy concentrate....from japan.....Its an oven baked 2k transparent candy and if you want it to come out nice you have to get the covers polished to a mirror finish first and paint it in a completly dust free enviroment(a spray oven) ....this means $$$$ oh no wait.... you might be able to put a sticker on them!
Goddam ricer.
lmao.
Get a new paint job you homeless f#ck, driving around in a car which looks like an empty can of sardines... get out'a here.... Go find half a big mac to feed to ya kids living under the bridge & VACUUM under your bridge there's sh#t everywhere.... *jokes just jokes, its rodney rude*
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
