Isn't it the other way around?  If all settings are at 0 the solenoid will stay closed, therefore the wastegate will see zero boost, therefore boost will hit maximum?
I would have thought all settings would need to be at 100%.......
Correct, even I have dumb days occasionally :O
:) cheers :O
  • Replies 1k
Posted Images
Just a simple question about wiring the solenoid to the IEBC - does the IEBC ground the wire connected to the solenoid, in the same way as the ECU normally does to open it?  Or does the solenoid need to be rewired so the IEBC operates it via a positive signal, rather than an earth?
Ok, dumb question on my part. I just found the book, and the specifications clearly say "Output signal.....switch to ground to drive solenoid connected to 12V supply".
Yeah. That's right... all you need to do iin a skyline is connect tto the wire from the ECU to the solenoid. The solenoid has an ignition switched power supplied to it on its other wire and the IEBC just earths the solenoid to open it...
I found this out the hard way. This thread was really handy when I was confused...
How hard is the DFA to tune, i.e. can any tuner who can tune a full ECU / AFC learn it easily?
Simple, any fool (even me) can tune using thge DFA. An exeprienced tuner would do it in his sleep. If he hasn't seen a DFA before (unlikely as there are plenty around) explain to him how it works, the load points etc. That will save him a few minutes (and you some money) working out what the buttons do.
:huh: cheers :(
This is the 10 minute no cost boost to 0.5 bar rerouting of the vacuum hoses.  Disconnect the two vaccum hoses from the solenoid.  Then connect the boost feed (from the cross over pipe on the left of the picture) to a the standard T piece. Connect one side of the T piece  directly to the wastegate actuator (on the right of the picture).  The remaing connection on the T piece goes back into the inlet via the BOV return pipe (on the standard fitting).  Make sure to put the the standard brass restrictor in that vacuum hose to bypass the desired amount back into the turbo inlet. The standard bypass hole of 1.25 mm bypasses enough air flow for 0.5 bar.
wow what a read.
i've got a Q.
Is the resistrictor meant to stay where it is (from the intercooler) or go in another vacumm hose ?
cheers :)
Wow Wut a post , sore eyes now! Anyway if got the IEBC bult and ready to go on the car! my questions are
1: do i hook up the input signal to one of the wires going into the top of my injectors then run the wire through the firewall into the IEBC or do i find the wire on the ecu ?
2: Has anyone hooked up the IEBC to a CA18det? if so how the Sh@t do i find the injector wire off the ECU?
any help would be grea , thanks
High guys, i actually bought the IEBC and controller quite a ways back but due to lack of time it's been sitting in the cupboard. now i'm ready to build i have a drama i hope some of you can shed light on: how do you keep your soldering iron tip clean to take solder properly because mine keeps (oxydising?) and blackened causing the solder to bead instead of taking to the tip. I have an adjustable temp. iron and have tried varying temps around the 300D.C mark and have also tried a tip refresher product which works great on every part of the iron except the very tip.
So any advice would be most appreciated.Cheers in advance
time to buy a new tip. try get the brass wool type cleaner (like steel wool, but brass, or brass coloured) rather than wet sponge.
if u take the tip out and take it to jaycar see if they can match anything up.
wow what a read.
i've got a Q.
cheers :D
The restrcitor goes in the vacuum hose off the T piece to the turbo inlet, it limits the amount of bleed off from the wastegate actuator.
:D cheers :)
Hey guys,
Since I finally got off my ass and plumbed my Jaycar boost controller in today, I thought I would post up a few questions I have.
First. I've got an old bluebird with a CA18DET in it, the solenoid is a normally closed type which I used off the fuel system in an S13 sivlia. As it stands, the plumbing only goes plenum > solenoid > wastegate - I am not running a bleed vent back into the intake.
I 've tested the circuit out by setting like 2/3/4 injector loads to solenoid fully closed, and 5/6/7 to fully open, then I've revved the car in the driveway to test the solenoid is working by making sure that you can blow through it when you rev the engine a little. it seems to be workign perfectly.
The problem. I've set the solenoid to stay closed until around injector duty of approx 20+ then I first had it randomly opening up between 40 and 75% from injector loads 20 - 64. This was just to test out what the boost is like. What I noticed was that the boost only spiked once up to around 10psi, the rest of the time it was pretty much at the stock 8psi actuator level of boost. I had a few weird things happen in this time though. A few missfires at higher RPM - would this be a boost cut? it was a fair feeling surge in power.
I then set load points 20 - 40 to 35% open from above 20 load on the injector, and its pretty much a constant 8psi which is what stock actuator is at anyway! Does something not seem right that I need to use such a low % open on the solenoid? Or should I set it lower and try it out. I know for a fact that if its at fully closed I will get a large boost spike as I tested this out momentarily and as soon as the boost gauge went to 12psi I let the accelerator off.
Do I just need a really low % opening on the solenoid? Just weary as dont want to damage anything :P
EDIT: As I am only aiming to run about 12psi
Cheers.
Edited by simboo
Hey SK,
I am now the proud owner of a S2 Stagea, & i don't have the boost feed coming from the cooler pipe, it comes form the turbo outlet, & i'm not exactly sure where the restrictor is or if there is even one fitted? I disconnected the vac pipe to the BOV from the solenoid & stuck it on the tee. i got no idea how much boost it made, but DAMN did it go. Here's a pick of the standard setup with the locations of the pipes, how do i re-route them for about 10psi?
Hey guys,
First. I've got an old bluebird with a CA18DET in it, the solenoid is a normally closed type which I used off the fuel system in an S13 sivlia. As it stands, the plumbing only goes plenum > solenoid > wastegate - I am not running a bleed vent back into the intake. ..................
It won't work you MUST have a vent, otherwise there is nowhere for the trapped boost (pressure) to escape. So the wastegate stays open until the solenoid opens.
Put a vent in and try it. Your problems should have dissappeared.
:D cheers :(
Edited by Sydneykid
Hey SK,
The vacuum hoses may be in different positions, but they do EXACTLY the same things. The restrictor is simply there to dampen the boost/vacuum hits on the wastegate actuator.
You have a vacuum hose marked "from solenoid to BOV pipe" that is the return to air inlet, Nissan have saved a few cents and eliminated one extra fitting on the inlet pipework.
The restrictor should be in the hose from the turbo outlet to the T piece. I can't see from the pictures but it should be marked with a stripe (yellow or red) around the vacuum hose to show where the restrictor is located. Maybe check the vacuum hose from the T piece to the wastegate actuator. Nissan may have put it in there, it would have pretty much the same dampening effect.
:D cheers :(
Hello Techo
I also have an S2 and like you probably got confused with the description on hose routing in this thread as you wont find any hose with stripes of any colour on them.
If you see red on a hose, that is probably dried blood, spilt from trying to get those hoses off!
The T piece that is shaped like an 'F' has (as far as I can blow) nothing in it, And a good squeeze of all the pipes did not reveal any lumps that may be hiding a restrictor.
**Warning** "Danger Will Robinson!" When you swapped the hoses off the soleniod you will find that your turbo was free boosting (if that is the right term) and you were probably pushing 15 - 20 psi from 3500 rpm onwards ( as I found out on my first run). Don't do any experimentation until you get a boost gauge. Run the gauge from the blanked off nipple towards the rear of the plenum.
I am not sure how the soleniods works as my test run with a boost gauge (before any mods) showed that I could only get 5 psi across the rev range. Maybe that black and white wiring mod in the other thread will work.
To get the desired 10psi I plumbed in an aftermarket boost controller simply by pulling those two hoses off the solenoid and straight into the BC. Start with the tap turned right down and then increase 1 - 2 turns at a time.
Better still, get the jaycar set up. it costs about the same as a BC and works better.
P.S. Get a mate to watch the boost gauge when testing - it can become quite mesmerising watching that little needle when you should be watching for the next corner.
Thanks 3intheback,
it's all swapped back & i only took it for a little run with the hoses swapped, so hopefully no damage. (crosses fingers) I have done the solenoid wiring mod & it works quite well.
Thanks again,
Jeff
hey, i just tried to power on my DFC and well.. nothing on the hand controller at all... backlight doesnt even come on.. i tried hooking it straight up to my battery.. no change... i've checked all soldering points.. any ideas?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
