i belive its a fualty hand controller as i bruoght a dfa with hand cont and hand cont was flicking on and off so guest it was my fualty somewhere but no coz i just a iebc today and hooked everything spot on and hand cont is still flicking on and off so just tell jay car that the hand cont is faulty and they will replace it. cheers
  • 3 weeks later...
  • Replies 1k
Posted Images
Jaycar EBC
Jaycar DFA
Apexi SITC
HKS SLD
Nismo cat back (very quiet)
Catco high flow cat
R34GTT SMIC
Pipercross panel filter
Feels like around 160 4wkw at the moment
Plus the following, after this weekend, since I have to remove it all to replace the cracked exhaust manifold
Performance Metalcraft split dump and engine pipe combo, Thermo wrapped of course
GCG Ball Bearing High Flow turbo, I have put the smaller compressor housing on it, as I want to make sure it looses nothing for towing.
Then a road tune by me, planning on running up to the max that the standard injectors, at standard pressure, can handle.
If I think it needs more power, then I will stick a bolt on Nismo FPR on it and turn up the fuel pressure.
That should test out the rumour that Stagea fuel pumps flow more that R33GTST fuel pumps.
The target always has been 200 4wkw (double what it had standard), so I will throw it on the dyno to confirm that the target has been achieved.
:D cheers :D
I spent most of the weekend replacing the cracked manifold (pictures to follow), fitting the turbo and the split dump. I also did a bit of general maintenance at the same time, replaced some broken bolts, tidied up the intercooler joiners and clamps plus cleaned and re-oiled the Pipercross airfilter.
I didn’t finish till late last night, so no time for tuning. Just a quick drive to make sure it moved. Extreme R&R at 1.5 bar (oooooops) , so I reset the IEBC to 100% duty cycle which gave around 1 bar. Still a little R&R, but it’s plenty quick, before the standard ECU kills the fun.
The GCG Ball Bearing high flow (ex R32GTST) I put on had a 10 psi (R32GTST) wastegate actuator, compared to the 4/5 psi one that the Stagea comes with standard. First I flicked the IEBC over to the low boost setting of 8 psi (high was 10 psi to perserve the ceramic turbine), but that wasn't anywhere near enough to drop the boost from 1.5 bar down to a more R&R friendly 12 psi or so. I ran out of time (and energy) to decrease the size of the vent, maybe tonight. Although I doubt it, I have some suspension set up to do on the race team car (not a Skyline) for the Bathurst 12 Hour next weekend.
I still have the IEBC set to keep the wastegate closed for as long as possible, so it develops 0.5 bar at 2,500 rpm at 1 bar at 3,000 rpm. I will be able to improve that with the SITC as it can now take some more ignition advance, up to almost 3,000 rpm. Plus a bit of A/F ratio tuning will help as well. If I can get 0.5 bar at 2,000 rpm and 1 bar at say 2,600 rpm I will be happy.
The Performance Metalcraft split dump (also ex R32GTST) has added a nice rumble to the exhaust, much more than I remember it doing to the RB20DET when I fitted it to it. I ordered the split dump with an extra lambda sensor fitting, so it much easier to tune as the standard lambda sensor can stay in situ.
So the hard (dirty) work is almost done, now it’s time for some tuning (clean) work. I seem much more at home with the laptop these days than the spanners. This pretty much completes the list of mods I had in mind for the Stagea, maybe a adjustable fuel pressure regulator will be required to make the power target. Just some tuning to go. I will post up the SITC and DFA settings, plus the vent size change required and the IEBC mapping once I am happy with the results.
:down: cheers :huh:
The R&R was getting a bit annoying, stopping the WOT fun far to often. So I dropped the boost down until I couldn't feel any more R&R, that was ~13 psi. Which will have to do until after this weekend and the Bathurst 12 Hour race is over and I can spend some time tuning the DFA and SITC. Which should let me turn up the boost a bit more.
I will definitely have to finsih installing the HKS SLD, because it will most certainly exceed 180 kph next time on the track.
:laugh: cheers :huh:
This is the 10 minute no cost boost to 0.5 bar rerouting of the vacuum hoses. Disconnect the two vaccum hoses from the solenoid. Then connect the boost feed (from the cross over pipe on the left of the picture) to a the standard T piece. Connect one side of the T piece directly to the wastegate actuator (on the right of the picture). The remaing connection on the T piece goes back into the inlet via the BOV return pipe (on the standard fitting). Make sure to put the the standard brass restrictor in that vacuum hose to bypass the desired amount back into the turbo inlet. The standard bypass hole of 1.25 mm bypasses enough air flow for 0.5 bar.
:blush:
hey sidney kid with this 5 min job where do i put the resrictor ?
1- between the intercooler pipe and the T piece
2- between the T piece and the waste gate
or
3- between the Tpiece and the turbo air intake?
coz i have is how u show in picture and the resritor in between the intercooler pipe and the t piece and its a standard size 1.25 and its doing close to 0.7 and its fine when doing 0.5 but once i get to 0.7 or over it will start poping like a boost cut ... how do i solve this.
or
#3
:D cheers :)
  • 4 weeks later...
I have a brand new never used FULLY BUILT Hand controller and DFA (Digitial Fuel Adjuster) for sale. Tested and working on the bench. I bought and built the kit with every plan to put in my car, but then realised after doing all the hard work my GTR has to AFMs and therefore would require two DFA's. So I have upgraded to a power fc.
Will also through in the brand new 1.8m DB25 cable required for connecting the hand controller to the DFA
Complete kit for sale - $200 posted to anywhere in AUS
To buy the kits from Jaycar would cost you $90 DFA
$70 HC
$20 Cable Total $180
So you are paying $20 for my 6 hours labour to build the kits!!!! PLUS free Postage
There are picture all over this topic of what they look like, but if you really want photos PM me or something
I though it might be handy if I added the ECU pins I intend to use;
Fuel Adjuster;
Red = 12 volts + * Pin 31
Black = 12 volts - * Pin 32
Green = input from AFM * the cut wire that used to go to Pin 54
Black = output to ECU (where the AFM used to be connected)* Pin 54
Boost Controller;
Green = input from injector * Pin 101 (cylinder #1)
Black = output to the standard solenoid * the cut wire that used to go to Pin 104
I have now fully tested them and the connections are as posted above.:)
Are these the same pins for a R33 GTST?
  • 4 weeks later...
Did you cut the injector #1 wire, or just solder onto it? If you cut it, then theres your answer.
If not
- check boost/injector wires aren't reversed.
- remove one wire at a time
- at idle it should be doing nothing - what does the display show?
Just putting it out there, is there any chance we could create a sticky list of jaycar friendly tuners.
I know its relatively straight forward to tune, but would feel much better if I didn't have to explain
what the unit was, how it worked etc.
  • 4 weeks later...
hey guys some help/advice wanted, i have just installed the jaycar EBC and everything seems to be working ok however my boost is way too high. I have solenoid set to 100% just to keep it down to 13 psi (My bleed hole is only 1mm). I'm thinking my solenoid is faulty. I blew though it while it was set to 100% open and it was a noticeably restrictive is this normal or is it stuffed??? (it pulses ok). Anyone know what the coil impedance should be??? mine reads 35 ohms any help or input will be greatly appreciated.
cheers chris
Rigged it up as per instructions, intercooler pipe going to top of solenoid, then hose from bottom of solenoid goes to a t/piece, one to atmo with a 1.5mm restrictor and the other to the actuator.
Problem is, with IEBC set to 100% or 0% it makes no changes to boost what so ever. Occasionally on the handcontroller it reads a funny reading like a loose conection on the display screen. Load readings read fine when driving upto 64. High or low settings also have no change.
I just tested with ignition on and at 0% i cannot blow thru it. I increase percentage and you can hear the solenoid open and i can blow thru it.
Interesting as it appears to work , maybe something happens when i start the car? Or maybe its the funny connection i see?
Edited by Robo's
  • 1 month later...
  • 2 months later...
Hey
Was wondering if anyone has any photos of the completed kits?
I have never soldered before, and have almost finnish the EBC, done the hand controller, DFA is next...
I cant tell which out of the two largest chips is which on the EBC? Instructions are crap.
Photos would be handy as i also dont know where the big white resistor goes, and want to check everything in general.
I earthed the two silver brick thingo's as i think that is what the book wanted me to do?
-Ryan
Edited by Ryan1600
Hey
-Ryan
Hi Ryan, the big white resister doesn't go anywhere, it is for testing the voltages. How to test them is in the instructions. The 2 x IC's are marked with white paint, the instructions tell you where they go. It's in the fine print, but it is there.
Cheers
Gary
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
