has anyone tried this and what level of succes did you get with this setup?
pretty much my question is... is it worth going 26 cams for a rb20 with a big single, or should i look at more serious cams like hks jun et all ?
the turbo will be one of these "china" type turbos
.50 front .63 rear t3 flanged ... equivilant to the smallest gt30r around.
i suspect significant lag will be experienced, but would like to see if the rb26 cams in someones experience is worth doing. if they could reduce lag by around 500rpm compared to stock the price i can get the cams for would be worth it.
cheers
tj
1 - cams are definitely 100% gtr - i know where they came from
2- this turbo isnt china china - its from brazil, seemed to power gotboost to a 11.0 quite well, still fine, runnig alot more boost then i intend too
price is for my eyes only :) sorry dude
3 - cubes, replacement 20's are plentiful and cheap, ill take the risk
anyone with experinces though
I fitted GTR cams in the RB25DET and found, as advised by Ben at Racepace Melbourne (RPMGTR), that they have too much ramp angle causing loss of compression at low RPM, say under 5000, but over they felt pretty good, really good. These were the ones that destroyed Roy's top end, yet they worked to expectation in mine after a polish of the journals. I will be getting a regrind of the flanks to allow for use with the hydraulic lifters and will be posting results elsewhere.
.... These were the ones that destroyed Roy's top end, yet they worked to expectation in mine after a polish of the journals....
Tis was truly a sad day:(
Does anyone know the correct clearance between cams and the journals/caps? Since Geoff had the cams checked and they were true, it would seem that the damage was maybe done by the journal/cap i used off another RB20, as the clyinder where i used it was where the metals gal'd ?!?!?!?!
Is it possible that the clearance was just a little too tight? From memory my inlet cam showed a few wear marks as well. So just how critical are the tolerances when say your engine has 170,000kms on it, and the cams you are installing were from a low kms (something like 35,000km) GTR and the replacement bearing cap was off an unknown RB20...too many variables floating around in there?????
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
