  • Replies 132
Posted Images
Hey mate I'm after this drivers side, rear cradle bracket and pin.
The rear cradle bracket is circled in Green, and the pin is circled in Red.
The pin itself unbolts out of the chassis of the car.
dont have it,
sorry mate
  • 5 weeks later...
