this is how i have my gauge, i didnt want it to cause any blind spot or stand out to much so i built this with fibre glass and putty, i think it came out pretty good, not finished yet (this was a trial fit) what do you guys think?
hey looks pretty good, its like at the angle i want mine to sit at, actually facing me unlike the a-pillar pods you buy. did u buy it and modify it ? would you be willing to make any more :) lol
i made it from scratch, using pvc pipe, t shirt cloth and fibreglass resin, once i got the basic shape i liked i used body filler to get it smoth, then painted it. ( not completly finished yet) you could cover in leather or any other material aswell
if you live in perth i can help you make it.. otherwise pm me and i will give you help that way
Don't know where to mount the gauge but with respect to the AVC-R:
Thinking about mounting inside the Drivers Sun-visor. 3 reasons...
1) When not need it can be folded up and the AVC-R is out of site… Stealth install- less attractive to thieves (out of sight- out of mind).
2) When you do need to use it- if while driving- fold down the sun-visor and it’s direct line of site… don’t need to take your eyes of the road…
3) How often do you see mounted there?
Problems-
1) Running the cable from the appropriate areas up the inside of the drivers “A” pillar then into the visor.
2) Thickness and weight of the AVC-R would probably require the visor to be cut and some bracing inserted. It probably would not sit flush either.
I know it sounds like a big job but if people can do it to Mini TV’s you certainly can mount AVC-R. Your effort = Your time and money.
Also if you have the AVC-R (Air Volume Controller ?) it comes with a boost display. There for don’t require the boost gage- sell it and it’ should pay for some of the sun visor modifications.
My idear when I finly get my line...
Stuck with VL for now
anyone got sum pics of it mounted on a sunvisor?
I agree pics i want pics of the avc-r on the sunvisor ;) i thought of it and went hmmm nar, but if i can see pics that would be bloody awesome :(:D so come along people, get some pics rolling on :D
  • 1 month later...
hey guys, soz to dig this thread up again, but has anyone looked at mounting a boost gauge in the air vent on the right hand side of the steering wheel?? I have seen it done in a rexxie, but not sure if it would be possible in a R32, and i cant check it coz i aint got mine in OZ yet.
If some1 has done it, i would be keen on a pic of how it looks, or even just a measurement of the air vent itself would be kewl to see if it is possible...
cheers.
NAman - AVC-R stands for actuator valve controller type-r
oRiCLe - a 60mm gauge fits in there. I've got one there.
Attached is a really bad shot of my interior (it's really small as well). If I remember I'll take some photos of it tonight.
yeah, it's a pretty cool stealth set-up. Not my car though. It belongs to a friend of mine, in his GTI-R.
The flap was taken from another sun visor and is held either up, or down with magnets.
Yes, AVC-R does display boost graphically.
here's another pic of the visor with the fabric off. He cut out a recess for the AVC-R and cable and mounted it in.
that should give you some inspiration as to what is achievable.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
