$650,000 to decide a number plate slogan.
FARK ME DEAD! Im gonna go into Gov't consulting. Obviously you can rip em as hard as you want with nothing to worry about
Well actually the main part of the cost will be in replacing all the staionary etc apparently - but still it seems excessive to me.
Why don't they just bring back the good old "Victoria - The Garden State" one. That was nice.
How about
Victoria - Home of VB
Or
Victoria - Shaped Like a Triangle.
or
Victoria Victoria Victoria - Oi Oi Oi
Or
Victoria - We Couldn't Get the Olympics so we Settled for the Commonwealth Games.
Afterall - its that great event which is bringing about the need for this new slogan anyways.
Victoria - Not Any Other State
Victoria - Run For the Hills
Victoria - Welcome to Labour Country
Victoria - Tolls R Us
Victoria - Land Of The Defect
And just a quick note to those who get upset for getting defected for mods...Learn to deal with it kids. It's here to stay and the only way you won't be defected is to keep it stock or stealth :)
Victoria - You can keep it!
Victoria - Livable? NOT!
Victoria - Where else but Queensland?
Victoria - Owned by speed cameras.
Victoria - Can the last person on their way somewhere nice please turn off the lights?
Victoria - It's just too easy to hang sh*t on!
Well if it is going to be used to promote tourism, more appropriate slogans for overseas tourists should be:
VICTORIA - Where the fcuk is that?
VICTORIA - Who?
VICTORIA - Where?
VICTORIA - What's there?
VICTORIA - The bottom right hand corner down under
VICTORIA - Never heard of it!
VICTORIA - Wife of David
$650,000 ey?  So thats where all our speeding fines go to...
$650,000? Cameras on the Eastern make that in a week!
Victoria- The place to have your nuts ripped off
btw, you hear Peter Batchelor got a little slap from bracks?
is there any 24/7 speed cameras at any point of eastern freeway, eg. from chandler to near the city ? if so be specific would be helpful, not for stupidity but yeh, curious cause i constantly see spanners flying up ridiculously towards the city and im like erm... gay...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
