Hey guys, just in case anyone is interested - the inaugural Porsche Mt Buller Sprint is being held THIS WEEKEND at Mt Buller ski resort.
Weekend mountain entry is $10
Event times - http://www.mtbullersprint.com/schedule.html
Visit http://www.mtbullersprint.com for full details.
The event consists of Special stages, and a touring stage with a Hill climb style event run along the Mt Buller tourist road which will be closed for the duration of the event.
The event will cover some 16 kilometres, rising through over 1000 metres in altitude, along the Mt Buller Tourist Road to the Alpine Village atop Mount Buller.
The Porsche Mt Buller Sprint will provide safe spectator vantage points throughout the event. The Mt Buller Village will provide numerous vantage points for an exciting weekend of motorsport.
Mansfield Prologue Spectator Map
Mt Buller Spectator Map
Confirmed entries in the field consist of Ferrari's, Porsche's, and other exotic sports cars. All entries have been fully booked (100 car limit)
I'm thinking of going up there on Sunday to watch the action. Should be a good weekend.
:rofl:
This looks like a fantastic spectating event :rofl: The pics on their site are great, worth entering just to get shots of your car.
A lil off topic but what is this car that's part of it??? confuses me; tvr, jag, ford?
if you are going up to watch the action and come back on the same day....can i join you???
I'd say yes but I can't confirm I'm definitely going yet.... PM me your number and I'll give you a call on Saturday if I'm heading up.. it's quite a long drive, but some of the roads through Black Spur and Healesville are fantastic :(
I was there yesterday. It was an improvement on the organisation of last year, but communication to the crowds was apalling. During SS3 there was an enormous crash which lead to someone being airlifted out. The road was closed to all until 6pm... they could've let us all know what was going on instead of having us hang around waiting to leave for a couple of hours!
A great day nevertheless; it's such a great road to drive quick. I'll be up there again next year.
Just by the way - I'd quickly like to congratulate one of our estemed SAU Vic members - Geoff Beable - on another fine effort. He finished a very commendable 32nd outright.
All results can be found on the website.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
