i have found some sealed batteries at a very good price . they are simillar to odyssey but don't have the steel case . i have priced the odyssey 1200 at about $330 . i had the 800 odyssey in the gtr but because i may leave it for 2-3 in the garage sometimes it was going flat ( tracker , alarm ).
anyway these batteries are $140 wholesale and they are the same sise as the odyssey 1200 , same specs as well so i put 1 in the gtr and its great . it fits in the original spot but you have to get another clamp from an auto shop and it doesn't come with posts just stainess steel bolts .
anyone interested you can pm me and i'll put you in touch with the guy that sells them , not sure if he will post interstate but i can find out .
i have taken a pic of it but my dg cam battery is flat so i'll put a pic up tomorrow .
Edited by wrxhoon
https://www.sau.com.au/forums/topic/62252-sealed-batteries/
  • Replies 376
Posted Images
I compared the specs of the battery to those of the odyssey 1200 and they appear to be almost identical in every way. Even the dimensions are the same.The only difference is the steel jacket on the odyssey.
I have attatched some pictures of the new battery alongside my old Odyssey 800 for comparison.
https://www.sau.com.au/forums/topic/62252-sealed-batteries/#findComment-951122
Can you measure it up in cm please? that'll be nice... WxHxD
https://www.sau.com.au/forums/topic/62252-sealed-batteries/#findComment-971183
20x17x17 cm , it fits it the r33 but you need another bracket
Thank's... I had problem trying to get a Century doesnt' quite fit as the (+) cable terminal is a bit too short to reach the terminals on the battery :)
Also did u find out if there are any reseller for this in Victoria, and if not if it can be delivered interstate safely?
https://www.sau.com.au/forums/topic/62252-sealed-batteries/#findComment-971242
no one in vic as they dont have any distributors there they only import and sell in sydney , i'm sure it can be delivered in autralia post as it is totaly sealed and only weighs around 14-15 kg , if you are interested in 1 pm your phone and i'll get him to call you .
https://www.sau.com.au/forums/topic/62252-sealed-batteries/#findComment-971275
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
