I think he means sealed vs. unsealed batteries.
If they're not sealed, they give off gas (hydrogen?) - in an enclosed space, it can be explosive.
IN THEORY... 33 owners should only use sealed batteries. But of course, sealed ones are expensive.
T.
  • Replies 376
Posted Images
what u mean they are illegal in r33's...this coz they are boot mounted??? if they come standard with them shouldnt they be legal??
cheers...ben.
thats right illegal and dangerous , the ones that come from nissan are not sealed but they have a breather that goes under the boot , like jetski batteries bt here they intall normal batteries .
do you need to replace the mounting bracket, and clamps too?
just the top bracket you can use the old long bolts , i made my own top from stainless steel .
T.
spot on! this is what i was refering to!
so these are fully sealed and no need for the breather hose??
thats correct craved , they are fully sealed , just like odysey no breather hose , you can mount them on their side if you wish no need to be mounted upright .
hang on a sec... you said fully sealed & NO breather hose...
so this IS a dry cell battery, right?
nice.. will definately save up for one! but will have to save for connectors too (joy of running 0 guage wire) how big is that bolt into each terminal?
its about 6mm , you can probably use the connectors that you hve on the cable now
its what they call a gell cell , just like odysey .
  • 5 months later...
A while ago i did a group buy on sealed batteries .
Some people have been asking me if i can get them again .
I made some enquiries and depending on interest i can get them but the price is slightly higher $ 140 each .
These batteries are totaly sealed and they are a copy of the oddessy 1200 but without the steel casing .
Anyone interested in a battery ( its a must to have a sealed battery if its the boot , like the 33's and 34 gtrs ) let me know and if i get at least 5 people i'll get then .
Pick up in Sydney .
Any more info on the batteries?
How many CCA's?
I need a reasonably good battery for my amps and subs.
How much would postage be to Melbourne, 3030.
If not too high then i'll take one.
Cheers
Greg
possibly interested, based on the details and performance of the battery as compared to the oddessy...
Its exactly the same battery as the odyssey 1200 ( odyssey say 1200 cca but thats not true , they are 1200 c.a not cca )
Go to the odyssey website and look at the 1200 cca .
Thre is some pics and a comparo with the 800 ca odysey , i dont have a 1200 here to compare it with .
How many CCA's?
Cheers
Greg
Postage to melbourne would be about $20 .
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
