Hey guys its my bday again...and i was thinking of hiring a nice car to cruise in for a day or whatever...
does anyone know someone in the game? know any details? companys? prices? stuff like that...
i seem to be finding out you need to be 25ish....
just want a nice car....maybe convertable....for cruising....for a day
im 21 turning 22 tommorow if that helps....
thanks guys....
Fane
https://www.sau.com.au/forums/topic/62267-hire-a-porshe-or-something/
I had no luck finding something interesting for hire in perth so I ended up in a BMW Z4 form Budget in town.
It went OK but was nothing particularly special :)
It did manage to keep up with an SAU WA "cruise" which is a pretty good effort I think :cheers:
thanks memphis and cc i will investigate those ones too.
i was thinking that ric but if something happens then im stuffed and i want to be able to enjoy the day driving around rather than be worrying about the car allday :P and if something happened and we have to pay it could work out to be a very bad day.... :mad:
When I feel like, I go down to albany hwy straight from work, with fancy tie and suit...
it doenst always works, but I do get about 10 minutes of test drive on few cars :P
to the date
Hondy M2000
Merc ML500
Monaro
it works better if you bring your GF and she ask sales man if we could go for drive, instead of you...
cheers
Joe
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
