Hey guys,
Can you have a look a these photos for me?
Looks like it might not be a hig flow cat but i would have no idea.
The rest is 3 inch as in front/dump and cat back.
So if this isn't, i would like to get rid of the bottle neck.
Will i notice much difference?
Should be able to get one off ebay for $160 i hope.
Yibeda yibeda !
https://www.sau.com.au/forums/topic/62270-high-flow-cat-converter/
Hi Birnie
Doesn't look like it, but very hgard to tell from the outside!! take it off and whild looking through it, hold it up to the light, if you can see the light throgh the mesh, then it may be a high flow. I put a magnaflow in mine and they usually retail for ~ $400, I got it through a mate in the trade for $150.
I'd be careful of the $160 'high flow' cats - if the are the generic type, forget it! save the money and get one that has actual flow figures provided for it.
On the issue of liberating a few ponies, when I imported my car it had a full 3.5 inch system, no cat or mufflers, this is the only way to improve exhaust flow - but not legal :cheers:
noticed a drop in performance when I fitted the legal system - also slower to come onto boost.
Hey guys,
Yibeda yibeda !
get in contact with BATMBL on the forums here, i got mine off him a while ago, cant remember how much, but was cheaper than anyone else
i got one (including front/dump) for my 34 from BATMBL. Have fitted or driven the car yet :P but how'd you find the car after fitting the new cat?
cheers.
cheers.
i fitted his 3" front/dump also,
already had a 3" catback
it does the job, i dont really see the differences in all these cats, they all 3"
some are larger voloume. thats all
why pay $500 for 1kw difference?
A friend has a ballistic s/charged rodeo ute and has upgraded to some magic cats ( twin exhaust).
They are not fitted yet but the workshop is going to do a before and after with the old high flows first and then whack on the magic cats to see if they are all they are cracked up to be.
I will post results when its done.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
