Actually Dragzz, if you install the system yourself $350 is more than enough money for a 3point immobiliser, alarm and keyless entry. take a look at some of the recent articles on Autospeed.com about alarms on a budget.
The plastic thing on your keyring wont look as pretty as a $600 one but it will do the same job and cost you less.
Also, I've been reading those autospeed articles on the alarms and I fail to see what the difference is between like $1000 alarms and the $150 jaycar jobbies.
Can anyone enlighten me please?
Let's see the $1000 alarms would have:
Immobiliser 3points +
Alarm
Tilt sensor
Bonnet/boot sensor
Black wiring
Keyless entry
Maybe GPS & Keypad
$150 jaycar jobbies:
Alarm
Immobiliser 2 points (?)
$1200 Fitted and you can get the best protection , a tracker .
Who cares how many points you have they can easily be bypassed by experts , at least with the tracker you can immobilise the car as soon as the move it and you know where it is at all times , unless underground .
  • 1 month later...
Extra features available int he alarm, software programming and more inputs with different polarities is generally the difference between the cheaper adn the more expensive alarms, I am more inclined to pick up a more expensive alarm than a cheaper one as I generally use the extra options and features..
I also fit the alarms myself, I used to a lot of car installs for work, so alarms are a walk in the park for me.
Do you have any recommendations then yorik?
I'd like to have -
remote central
3 point immobiliser
extra inputs for tilt/boot/bonnet
siren output (not just horn)
black wiring
good code hopping
It'd be a bonus if it had auto arming, have silent arm/disarm and be able to lock the doors even when the engine was on (for warming the car up).
Cheers.
Hi Guys,
I need to find out what is a pretty good alarm system (upto about $350).
It is a must because of insurance.
Do you guys have any reccomendations??
Dragzz :headspin:
If your insurance company requires you to have an alarm installed, it is very important for you to get them to tell you which alarms are suitable.
Thanks chunners.
Funny enough I saw the "BW10000" on ebay also http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...ssPageName=WDVW
$170 is better than $250.
One thing did strike me as odd that the blackwidow webpage (www.blackwidow.com.au) doesn't list how many immobilisers it has.
I might end up just paying the guy who did my flatmates r32 the $400 he's askin to do the lot with the whizz bang system he reckons is best.
I'll think about it then and update the thread with my thoughts if I have any feedback worth giving :)
Cheers.
autowatch, brant, viper and mongoose are the only alarms that i'd ever have in my car. i had a warlock before and it was shit.
reliability, features, compliance to au/nz standards and actually PROTECTION from thieves are there in spades with the right alarm. a $100 jaycar job is a walk in the park to get around. i watched a guy do it at a place i used to work at and it was just too easy for him! (hifi store).
but as they say, an alarm is only as good as its installer. a stratties job may very well be fine, but they install it with hotmelt and wishful thinking, your better off leaving the keys in the ignition.
d
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
