oh so your the guy who had the car towed up all the way from wollongong. Yeah they are the official repairers for Famous Car insurance and a few other insurance companies.
In that case I better make sure they do their job properly. A workshop is only good as its workers. Like any workshop you ocassionally have a few unhappy customers but overall Tai does a great job. Tai owns the business now. Every car around cabramatta goes to Stevens Prestige.
Hi Andrew :( how you been . Havent forgot about my buddy Nick either :)
Btw Im Minh. :)
Hi Andrew :) how you been . Havent forgot about my buddy Nick either :)
G'day Minh! How's your butt going without me around to kaboom it every now and then? :(
You still got your GTR? I'm going to be selling mine very soon :)
Nah my GTr is with Steve now. He is trying to sell it, why you letting your one go? :)
I drove a 2 door sti around for awhile. I sold that two weeks ago too so I been walking around. Twin leg power. Getting a S15 soon. Just stocker. gotta save for wedding this year. Cant keep getting raped by young thai boys who own skylines I ran out of vaseline. :(
Letting mine go because I don't drive it anymore :) I've moved onto a slow-ass euro car and I might as well sell the GTR and let someone else enjoy it instead of having it sit in my garage gathering dust :)
Yah... S15s are nice :) I can't wait until they drop to $20k-ish and I'll get one for a track bitch :) :) :)
yeah hes the one im dealing with.
im going to try and make an effort to come check teh car out.
just want to make sure im getting the same front bar that i had and also the same grill.
ill only really need a courtesy car if my car is going to take a while to repair.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
