A DRIVER was trapped in the wreckage of his car for more than an hour today in Canberra as emergency crews cut the roof off the vehicle to free him.
The man, aged in his 20s, suffered a broken leg after his Nissan Skyline was wrapped around a light pole about 5am (AEDT).
A male passenger was treated at the scene for minor injuries before both men were taken to Canberra Hospital.
It took almost an hour to remove the driver from the vehicle because his legs were trapped, a spokesman for the ACT Emergency Services Authority said.
Advertisement:
A spokesman for the Australian Federal Police's ACT division said the accident was under investigation and the driver would be tested for alcohol levels when his condition permitted.
No other vehicle was involved in the accident.
Hope it wasnt anyone here!
https://www.sau.com.au/forums/topic/62821-uh-ohs/
I'm suprised that the media bandwagon hasn't jumped right back onto the whole "killer Skyline" thing or the "reckless P plater" thing to bring us more coverage of the crash...It seems that everyone knows everyone,or someone who does,in Canberra-it's a suprise that we haven't found out which car/driver it was.Whilst I wouldn't wish ill of anyone injured in any car crash,if the small bit of media we've heard holds any truth about the alcohol level of the driver,well...
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1184484
page seven of the canberra times...
it's a two tone series I 33, gold(ish) wheels from what i saw in the photo. wasn't YGT25T was it? said the driver was a 25yr old from dunlop, cause of the crash was alcohol and speed, going too quickly around a corner.
the car wrapped itself on a wooden electrical pole on the center pillar driver's side, firies cut off the roof of the car
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1184641
saw the pic: i think its pretty much silver, not a whole done to it from the looks, body is stock and nothing really special, although it now has a side-mount telegraph pole.
i hav'nt seen it before and i think i can safely say its none of us.
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1184887
thats exactly what i thought, infact i was thinking id hear it on the news or see it in the paper under very similar headlines but nothing as yet.
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1185090
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
