A DRIVER was trapped in the wreckage of his car for more than an hour today in Canberra as emergency crews cut the roof off the vehicle to free him.
The man, aged in his 20s, suffered a broken leg after his Nissan Skyline was wrapped around a light pole about 5am (AEDT).
A male passenger was treated at the scene for minor injuries before both men were taken to Canberra Hospital.
It took almost an hour to remove the driver from the vehicle because his legs were trapped, a spokesman for the ACT Emergency Services Authority said.
Advertisement:
A spokesman for the Australian Federal Police's ACT division said the accident was under investigation and the driver would be tested for alcohol levels when his condition permitted.
No other vehicle was involved in the accident.
Hope it wasnt anyone here!
https://www.sau.com.au/forums/topic/62821-uh-ohs/
I'm suprised that the media bandwagon hasn't jumped right back onto the whole "killer Skyline" thing or the "reckless P plater" thing to bring us more coverage of the crash...It seems that everyone knows everyone,or someone who does,in Canberra-it's a suprise that we haven't found out which car/driver it was.Whilst I wouldn't wish ill of anyone injured in any car crash,if the small bit of media we've heard holds any truth about the alcohol level of the driver,well...
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1184484
page seven of the canberra times...
it's a two tone series I 33, gold(ish) wheels from what i saw in the photo. wasn't YGT25T was it? said the driver was a 25yr old from dunlop, cause of the crash was alcohol and speed, going too quickly around a corner.
the car wrapped itself on a wooden electrical pole on the center pillar driver's side, firies cut off the roof of the car
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1184641
saw the pic: i think its pretty much silver, not a whole done to it from the looks, body is stock and nothing really special, although it now has a side-mount telegraph pole.
i hav'nt seen it before and i think i can safely say its none of us.
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1184887
thats exactly what i thought, infact i was thinking id hear it on the news or see it in the paper under very similar headlines but nothing as yet.
https://www.sau.com.au/forums/topic/62821-uh-ohs/#findComment-1185090
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
