Automatic Transmission Shift Kit. - Updated Oct 2006
thanks, called him, looks like I didnt hook up the selector valve linkage, but now i have problem of locating another spring, which i have damaged, dont ask how :) If anyone in Brisbane area has a wrecked automatic transmission, please let me know, thanks
  • 1 month later...
Anyone know a good place in Sydney to get the valve body and torque converter removed to send off ?
Mike doesnt have any to send out anymore :sleep:
Spoke to my normal mechanic said they won't touch the auto box.
Anyone in brisbane has done this before? I'm really interested in getting this shift kit but I just don't know where and how to get it done...
How do we ship the old valve body assembly back anyway? Can we just take it to the post office...?
got mine done in Dec, pulled it out, packed it up, sent it express post from P.O., approx $50 i think, he modifies yours, depending what stage (spec) you want, bills your CC, had it back in approx 4 days. then fitted it myself. very ,messy job though, make sure you have lots of rags.
Edited by chook
Sounds exciting! But i don't have any tools, and the landlord of the place I'm renting is a clean freak, so i'll need to find a workshop or someone to do it for me. :D
Anyone wants to help me out (i'll pay, of course), or knows of a good place to get it done?
hey mate
i had mine installed by mercury motorsport. they aren't automatic specialists, just mechanics, but they did mine and it came out perfectly. plus their used nice fluid.. motul..
and.. they sent it back for me using their courier account, so came to pretty cheap compared to sending it myself with australia post
hey mate
Ah..! I see. Thanks a lot ^_^
My problem is mostly the 1st - 2nd shift and to a lesser extent the 2nd - 3rd shift, 3rd - 4th seems unchanged. When it changes i just feels like the gear is engaged too quickly. At modest throttle levels (what i would call normal acceleration) the change jerks your head back even though you arent really going that quick. At full throttle i can feel the tyres break traction for a little bit and the car has a short burst of acceleration. Apart from being quite irritating i think this puts a lot of extra stress on the drivetrain. Keep in mind my engine is dead stock so i can't imagine what it would be like on some thing with a bit more poke.
I have spoken to MV automatics about it and he has offered the 'next level down' which is supposed to be 30-40% of what i have, however he has said the brass plugs that replace the springs and modify the overlap stay. I'm thinking it may be the overlap change which is the source of my irritation. Anyway i have decided to go back to stock. This was in part something i wanted to try to reduce stress on the tranny when i get an aftermarket ECU, but i think it will just spend more time making sure its electronically interfaced and doing what it should.
This isn't a slight against MV Automatics or there product it just wasn't what i am after.
Hi guys, just trying to get an idea here, overall besides the quicker shifts, would it be that sufficient to have the shift kit in say if I was running over 300rwhp with a PFC etc? I was thinking of just putting in a trans cooler only. I'm mearly concerned with the life of the gear box.
Cheers!
Cheers!
Quicker changes will reduce the wear of the auto cluches and reduce heat, so it will improve the life of the auto (not reduce it)
A trans cooler will cool down the oil (heat that comes from the torque converter) and will also help improve the life of the auto.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
