Automatic Transmission Shift Kit. - Updated Oct 2006
hey guys ive click on the link to learn more about this but leads me to the front page forum. can someone help me out with the link or just explain what it is exactly? ive just moved to skyline a couple of weeks ago after been driving my clubby so purchased auto r33 gtst s2.
thanks.
thanks.
I did a search but couldnt find the original thread the link went to, probably lost.
Give Mike a call (number is on the first post) or email him at MV Automatics (think the address is in here somewhere or use whitepages.com.au) for specific information on hi stall torque converters or for more info on the valve bodies (they are a great mod and well worth the money)
just got off from work so mv should be closed. will try to call tomorrow before the weekends. just a question though if i install this shift kit would the bov sound still sound the same as i know it shifts much quicker between gears then my stock.
^^^ The quicker shifts won't effect affect the function/ sound of your bov. Unlike with manuals you don't normally lift from the gas pedal (closing the throttle) during shifts so the bov shouldn't open which means no sound.
Anyone had a go at installing one themselves and want to share? Difficulty level?
I recently had my trans serviced (ATF flushed and replaced) so dont want to fork out all that money again....argh.
I have access to a hydrolic hoist, all the right tools ect.
  • 4 months later...
Honestly, this it quite easy just need to take your time and be very methodical about it. The little black box is also pretty easy to install, as long as you follow the instructions and again take your time. And even if you do got stuck give Mike a call.
The hardiest part is holding the new part up while doing up the bolts.
  • 3 months later...
fitting a Stage 1 MV Automatics valve body at the moment, Mike's notes says to block off and remove springs for the middle 2 acumulators with welsh plugs, done.
But i seem to remember on a previous install that only 1 of the end springs goes back in, but in his notes it implies that both end springs are retained.
Anyone done an install in an R34 'b' box lately and can shed some light ?
thanks
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem. However, before you PM me think about this.
A group buy, is a group of people buying the product together to lower the price.
Buying single units here and there is not what constitutes a GROUP BUY
Thanks
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
