Can you post a photo?
Here's a few ways to tell the difference:
R34N1's are ball bearing (see if it spins easy)
R34N1's have 9 blades on the turbine compared to 11 for the R33
R34N1's compressor housing does NOT have the A/R marked on it
R34N1's have a divider between the wastegate and turbine
You should be able to work it out from that.
Cheers,
Gary.
Guest Mashrock
Gees, thanks for the info. Guess they're not 34s cause A/R is marked and plus there is no divider for wastegate gases...but they sure as hell spin easily. They're actualy meant toi be NISMO N1s. Could these be BB?
all n1's are bb, i beleive.
quick queation how much u pick them up for?
and are you doing cams also. this would be rather advised.
Just a note on this i just recently picked up two brand new R34 N1 turbos for my GTR so new they had not even been removed from the nissan box and wrapping.
the only cost me $3000 for the two, and thats to my door. i know a guy who sells them for about $2800 for the pair brand new :bananaman
Guest Mashrock
with n1 actuators?
is that how its spelt??
with n1 actuators?
yep with n1 actuaters well there direct from nissan so what ever ones they fit on them there nice and small compared to all the other turbos i have bought in the past for my other cars.
My bro got them from Banzai motorsports for ~$2500 I think (ANTS?).
Cams... what size do you recommend? Its true that the GTR has piss small cams standard (unlike the FJ20). Personally, I think a GT3540 plus a set of 272s would be nice!
Dude, turbs cost me $1,900 from Banzai.
Yes, I agree GT3540 would be nice. Pls buy me one.
Seb, I also got a new exhaust manifold gasket today from Hi Octane Racing.
Now filing for bankruptcy. :P
OohArrGtr
check the serial number (from above post) - if they are R34s - then they should be good for 600+ hp on your GTR.
I have just had a pair fitted - waiting to run in the new bottom end.
BTW - nismo.com.au list them as 320hp and are selling the pair for $4K + I think
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
