Can you post a photo?
Here's a few ways to tell the difference:
R34N1's are ball bearing (see if it spins easy)
R34N1's have 9 blades on the turbine compared to 11 for the R33
R34N1's compressor housing does NOT have the A/R marked on it
R34N1's have a divider between the wastegate and turbine
You should be able to work it out from that.
Cheers,
Gary.
Guest Mashrock
Gees, thanks for the info. Guess they're not 34s cause A/R is marked and plus there is no divider for wastegate gases...but they sure as hell spin easily. They're actualy meant toi be NISMO N1s. Could these be BB?
all n1's are bb, i beleive.
quick queation how much u pick them up for?
and are you doing cams also. this would be rather advised.
Just a note on this i just recently picked up two brand new R34 N1 turbos for my GTR so new they had not even been removed from the nissan box and wrapping.
the only cost me $3000 for the two, and thats to my door. i know a guy who sells them for about $2800 for the pair brand new :bananaman
Guest Mashrock
with n1 actuators?
is that how its spelt??
with n1 actuators?
yep with n1 actuaters well there direct from nissan so what ever ones they fit on them there nice and small compared to all the other turbos i have bought in the past for my other cars.
My bro got them from Banzai motorsports for ~$2500 I think (ANTS?).
Cams... what size do you recommend? Its true that the GTR has piss small cams standard (unlike the FJ20). Personally, I think a GT3540 plus a set of 272s would be nice!
Dude, turbs cost me $1,900 from Banzai.
Yes, I agree GT3540 would be nice. Pls buy me one.
Seb, I also got a new exhaust manifold gasket today from Hi Octane Racing.
Now filing for bankruptcy. :P
OohArrGtr
check the serial number (from above post) - if they are R34s - then they should be good for 600+ hp on your GTR.
I have just had a pair fitted - waiting to run in the new bottom end.
BTW - nismo.com.au list them as 320hp and are selling the pair for $4K + I think
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
