Im new to the r30 but took one on a test drive an loved the lsd irs and the brakies it did and with full electrics i had to buy it for $1,200. The only problem being its sluggy 2.4ltr.
I was just wondering whats involved in converting it to an rb20 turbo out of an r32 skyline. It will be manual and i was also wanting to put in the diff and do a full brake conversion from the 32. Is it worth it??
https://www.sau.com.au/forums/topic/63034-r30-rb20t-conversion/
Welcome to old skool skylines!
It depends on how much you love the car whether not not it is worth it...
For the money it would cost to do the complete job you are describing....you could probably buy an R32 gts-t.
Unless of course, you are doing the work yourself. in which case, Yes, it would be worth it.
You could go the old-school L20ET (guess what's sitting out in my garage?).
My understanding is that the RB20DET will drop in if you fit the X-member from a R31 Skyline. I've yet to discover how the gearbox will go (it will need to be a RB-series box, the L-series won't bolt up), but I'm sure you would certainly require a custom tailshaft.
RB20DET is bolt in and would cost around $1500 for a motor, box, ecu and loom, and around $150 to modify tailshaft, about $500 give or take, to wire it up, you also need intercooler, fuel pump, air filter, exhaust etc etc. cheaper and easier then you may think tho :D
Now this is the good part my mate smashed his r32 a year ago and now just wants to get rid of the wreak so i have a whole r32 complete except for the radiator and front left quarter panel and the bent roof.
Now ill be doing all the work myself to keep the costs right down as ive done heaps of work on imports before like coolers + piping.
I just also need to know does the r32 diff bolt in and with the brakes whats the best way to go. Should i use the r32 rotors and calipers or is there a better alternative.
you will find that the halfshafts have 5 bolts in the 32 and the r30 has 6.....but if you get early(88/89) silvia halfshafts they SHOULD bolt straight in. diff is not a straight bolt in affair, but its close....doesnt takemuch to do it....
just becareful with the axle length, as R200's are a lot wider.
r32 brakes are not going to fit unless you use ither hr31 import struts or s-13 coilovers and s-13 hubs, not as hard as you might think, though i havent done the work yet, have all the bits just no time...once i do the work i'll then have a brand new set of Koni adj struts,king springs and DBA slotted rotors for sale all done less than 100km. hint hint.....
For brakes, I'm working on a a conversion using the early (4-stud) Z31 rotors and hubs. These fit straight onto the R30 stub axles (have to remove the backing plate). Just need to figure out how to adapt the calipers (they are 100mm centres on the mounting holes, R30 is 90mm). Then you can run 4-spotters if you wish.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
