What rpm was the 108rwkw made at? Also what was your tourqe figure and at what rpm? I pulled 119rwkw with a 3"cat back, pod, thermo fan, no aircon. I was a bit dissapointed but I guess I wanted to much! The thing pulls great though!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
yeah, im kainda disappointed, i had changed oil and fulel filter, engine oil, spark plugs, to brand new iridiums bout 20 mins before... had that mobil 8000 shit which i find better than optimax and was hopin for about 110@ wheels my second run was worse, only made 99.7kw @ wheels..
they said full exhaust (dump, front pipe, hi-flo cat etc.) and boosted will make guaranteed 150 at wheels?????
That would seem about right actually, a guy at my work has the R32 Silvertop in his HR31 coupe, it is completely standard including airbox and all. The only thing it has is a bleed valve set at 10psi and it made 127rwkw so your figure on stock boost seems about right.
10psi is stock on silvertops anyways i thought
i picked up 20kw at rears from a turbo dump back 3inch hiflow exhaust ..mind u my ole school ECCS redtop 20det only made 96rwkw bog stock as a rock with auto .....
Matt
I made 149rwkw's with full 3" exhaust from turbo back, 11PSI and a hot air pod! Exhaust would have to be one of the best early upgrade mods u can do!
what is essentially the difference between stainless exhausts and mild steel... i can only see one which is on has a bling factor, and also gives the node a bit more of a metalic sound to it... and doesn't expand as much as parsay... and the other is just mild steel... dunno
exactly what u said, oh and also doesn't rust, i'd just go mild steel!
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
