hey how can i get more power from me RB20, it currently has a High Flowed turbo (laggy as all hell), 3 inch exhaust turbo back, HKS front mount, a japan tuned rom, and 1 bar boost, it has a stocko fuel system and stock internals.. i need a good recipe to make 250 - 280rwkw....will the high flowed unit do this, and wat should i get done to make this power? :flamed:
https://www.sau.com.au/forums/topic/63096-rb20-more-power/
hey how can i get more power from me RB20, :
This question has been done to death, you can find a hell of a lot on RB20's by using the search function.
But since it is dear to me I will say that you probably need to backcut the turbine wheel, replace the CAT with a GTR's, modify head, Adj Cam gears, = AIR OUT
Replace the Injectors with 550's, New 040 Bosch in tank Fuel pump, Rising rate FPR, = FUEL IN
Modify the Airbox for more cool air in, replace the filter - DONT FIT A POD, see BAS JUNKY's Group buy on mod TurboDuct, modified Intake -reduced length piping, modify Head, Adj. cam gears = AIR IN.
NewECU or recalibrate orig ECU = CONTROL
FUEL IN + AIR IN
--------------------- = AIR OUT = POWER!!!
CONTROL
Or something like that.....
https://www.sau.com.au/forums/topic/63096-rb20-more-power/#findComment-1187957
you'd need to know more on the turbo itself...
sounds like it could possibly be an rb25 unit highflowed to probably suit a 2.5L rather than a 2L .. hence the lag.. not enough capacity flowing from the 2L to spool it up quick enough.
https://www.sau.com.au/forums/topic/63096-rb20-more-power/#findComment-1188080
nah its really laggy, my mate that owned the car b4 me got it done he just took it to some place at slack creek (i think AGC Performance or sumthing) he got a steel wheel put in it and the center section isnt an rb20 one. He never got ball bearings put in it cos it was costing him to much, so she doesnt hit full boost till 5000rpm, im goin to get ball bearings put in it though to help this lag. i think its just one of those standard high flowed jobs that most people get done
https://www.sau.com.au/forums/topic/63096-rb20-more-power/#findComment-1188092
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
