The iridium and platinum plugs are good, and have a long service life compared to the coppers, but if your planning on boosting, or already have an RB25T, then just go the copper!
Reason: You'd be wasting your money going for the others, as the 25T tends to run very rich without aftermarket management, meaning your new expensive plugs will get fouled just as quickly, and need to be pulled out to be cleaned.... and there is only a certain amount of times you can do this.
So....
If you are going to pull them out anyway, in the long run it will cost about the same to keep putting new coppers in every time you pulled them out! I know I'd rather be putting new plugs in every time! Also the amount of spark generated by any of these plugs is just the same!
If you want a good copper plug, try:
NGK BCPR6E (or if u dont find them, try BCPR6ES)
The plug without the S is the v-groove, which gives off a slightly better spark.
Almost forgot, regap them to about 0.7, maybe even as low as 0.65 if your planning on really cranking up the boost.
Zahos
5's are a warmer plug.
I'd assume putting the 5's in means that the plug is not capable of dissapating heat fast enough and the HOT plug will pre-ignite the fuel, causing the car to ping under high load and high boost.
6 is the recomended heat rating for the RB20/25 (dont know about RB26). Unless you have heavily modded the car, and/or have aftermarket/re-mapped management, I wouldn't go cooler than 6, as the plugs will foul easily (found this out from experience).
Zahos is correct.
While i was learning about electricity, Silver is the best conductor of electricity, second to that is copper, then it goes down the list & iridiums & platinum golds goes somewhere down the list.
iridium and platinum are good plugs but i wouldnt spend $18.50+ for a single plug that last longer.
*Note* if your getting Copper (which i reckon you should) change them as often as you change your engine oil as they dont last long.
I would go for cheap copper ones gapped to .8 & have them at heat range of 6-7 depending on how much power your car is making.
I blew a spark plug (Iridium heat range6) on my RB20det doin 162rwkw & Now i got copper with heat range of 7 & does great.
Originally posted by Joe
Zahos is correct.
Gold and platinum are EXCELLENT conductors :D
Originally posted by SPOOLIN
Ok feel free to shoot me down, But why has ALL of the top end audio gear got Gold connectors?? If Copper & Silver are the best conductors wouldn't it be cheaper to use this?
Lee
LOL god if i know man, i was taught that from the text books & welding books.
but then again how can we compair the amount of power used on a Welding machine to a 12a powered amp.
But i cant answer your question, its might be gold plated i doubt anything would be fully gold.
Lee
Hehe ok last msg off topic :lol:
Being an Electronics tech i can tell ya that Gold is the best conductor all round, doesnt tarnish either,
Conectors and audio gear is usually thin plated with 24k gold and this provides the conductivity and also protects the copper item underneath
Silver then copper maybe there are a few diff metals in between but at my work to get a good busbar we take the copper bar and plate it in silver which rates the item higher in conductivity and heat transfer
Thats why these plug tips are made from these materials such as IR Platinum Cop and so on
NOT true.
Just some facts on copper, silver and gold:
Copper: electrical resistivity 1.7E-8 Ohm.m, thermal conductivity 400 W/m/K.
Silver: electrical resistivity 1.6E-8 Ohm.m, thermal conductivity 430 W/m/K.
Gold: electrical resistivity 2.2E-8 Ohm.m, thermal conductivity 320 W/m/K.
(All data courtesy of webelements.com)
As you can see, silver has the lowest electrical resistivity, hence the highest electrical conductivity. It also has the highest thermal conductivity. On the other hand, gold is the last on the list both in terms of electrical and thermal conductivity.
So, why is gold used on audio connectors? Because it LOOKS good and it doesn't oxidise as easily as silver or copper (it has the highest electron affinity amongst the three). Silver is used for internal electrical contacts such as in switches and relays, because you cannot show them off, so the best material is used rather than the prettiest.
Bullshit only power relays are pure silver while 90% are gold most edge connectors are gold we use gold components at work for alot of electrical apps most of them are unseen.
silver is only used to stop arcing
I agree that Gold isnt the most thermal but whoopdy do this thead aint about metals as such anyway mr i know everything about cold metals
cheers
All I am saying is that silver has the highest known electrical and thermal conductivity of all metals. That is a fact. Cold hard facts do not lie. Check the figures out yourself if you don't believe me, any good chemistry book will do. Alternatively, do a search on the net. Therefore, the fact that gold is used extensively in electronics must be due to something else other than electrical conductivity, such as superior corrosion resistance and nice appearance. I rest my case.
P.S. The moment you assume you know everything, you lose the plot. Nobody knows everything. Life is a long journey of continous learning and discovery. I am but a humble student.
Ahhdeeaahh
I never said at any point that silver Wasnt electrically AND thermally the best conductive of all metals.
Ok what ever...case closed......
not jacking this thread any more..
Henros I know what your getting at but i dont agree with u entirely...........!
But im not going on about it in this thread allthough interesting issue......cheers :)
mac
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
