  • Replies 90
  • 1 month later...
Hi everyone,
i am finally back from my holiday! i know about everyone is dying to get their hands on the bonnet.
Maybe it is good to give you guys some update.
The bonnet is ready! Yippe!
However the ship to bring it to sydney is facing delay! Boooo! Grrr!!! :D
The good news is that it is already on the way! but the arrival will be later.
ETA will be mid to late april and subjected to custom clearance.
I do want to apologise for the lack of updates.
I have been away for 6 weeks and it is hard to find internet and 2ndly i am not to logged in as SAU only allow local IP address to go in!
But rest assured your bonnet will be here.
I have been selling online for a while and my reputation speak for itself as i do sell on other forums as well.
I have 26bonnets in this shipment and please do not hesitate to contact me further if you need any more clarification....
also i have been trying to increase my Skyline knowledge and has bought these 2 books during my holiday. i hope to be able to bring in more skyline products in the future.
Thank your for all your supports! ;)
Cant wait for my bonnet aswell :P
Can you get CF bootlids?
at this time they only produce for subaru! BOOO! :)
i ask them to make for skyline as well
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
