  • Replies 184
Guest two.06l
Paul are you all G'd up for sat?
I'll be there but only watching as i know our car would spit a gear box if we push it much harder.
Also whats the Quickest time you have run so far? I'm sure that will get slashed on sat though.
Cheers
gotta instal a tailshaft loop...WTF...these ANDRA tech inspectors are starting to p1ss me off. Not g'd up...absolutely exhausted from prepping car. Quickest time...ive never driven the car so the quickest time will be easy to beat.
Guest two.06l
Are you getting the car tech inspected by Saturday?
Tailshaft loop, scatter shield, race suit and boots ;)
scatter shield...check
6 point cage...check
ANDRA UDL licence...check
vehicle log book...check
battery isolation switch...check
5 point harness...check
arm restraints...check
helmet...check
race suit...check
red racing boots...check
and then the bastard tells me ive got no tailshaft loop.
guess who's going to be busy tomm.
Guest two.06l
The one you told me about at Powercruise
yeah we got dudded...Stace picked up the box yesterday, brought it to the workshop. Guess what we found inside when we split the case.....the most thrashed STANDARD R32 GTR box ive ever seen (besides the one i smashed at the creek)...third gear had nearly every second tooth chipped and second wasnt too crash hot either. NOT HAPPY JAN!
So in true "team twoogle" DIRTgarage style we built ourselves a semi-decent..(if there is such a thing) std box out of the parts we had available. Hell we even have a reverse gear now.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
