A lightweight flywheel is a good move.
Accelleration is improved full stop.
Torque decrease ----- false. Absolute rubbish!!!
Can't go up hills as quick ---- false. as above.
As a reccomendation go get a Ogrua lightweight flywheel or something similar they weigh 4.8kgs, the drivabillity is very good for the street with stock like characteristics.
Do not lighten the factory unit. Cast iron only has strength in the outer skin. If you take enough material out you drastically weaken the unit. There are plenty of cases of these sort of flywheels exploding and causing damage and injury. There are also plenty of people going around with them who haven't had one let go but, when you consider the aftermarket ones are much lighter still and being chromemolly will never 'explode', for $500 who would argue with that.
  • Replies 69
I think the less torque theory comes from Gran Turismo :P
That 'simulation' game? :) hehehe
I was thinking about it a bit more tonite. How can it lose torque? You pull the engine out its still got the same amout. At the wheels it might make a difference, but after driving round tonite thinking about it, I dont think it does hey. And just listening to the rev speed of my car to other rb20s I think it makes a fair difference. BTW I have a JUN lightweight wheel in mine.
Chromoly won't explode but heavy-ass clutches and indiscriminant use can 'burn' straight through them.  Food for thought.
Adrian
i also heard the same adrian stop me from getting one when i replace my clutch didnt like the idea of destoring it
i have one in my daily driver
went from a 13.4kg stocker to a 4.5kg lightened one, that has most of the weight on the inside and very little on the outside
this one infact VV
its alot better IMO, i have no problems using it for driving in heavy traffic, i consider it to be an all round improvement. only different is you need to slip the clutch a tiny bit more to engage it at low speeds, and that it will punish you more if you make a bad gearchange. but really at the end of the day you will be a better driver for having one and it improves the cars revability and acceleration, not by a huge amount but a definate improvement. took me about 4 days to get used to and since then i havent looked back
People that have driven my car with the lighter flywheel always commented how it rev'd a lot easier.
this was before i did all my mods and it was making ~185-200rwkw like most melb R33's depending on your dyno choice.
Adrian
I think you got mixed up there.
The metal used in the construction of the aftermarket flywheels is harder than cast iron. It is in fact the lightened cast iron flywheels with no hard outer skin left that get eaten through, that is why they explode and the chromemolly ones don't . All triple and quadruple plate clutch systems designed for mega horsepower utilise chromemolly flywheels as a part of the package not cast iron. Cast iron flywheels require 'skimming' when replacing even organic based factory clutchs. 'Chromemolly steel' never requires this. Some really good flywheel packages are even gas nitrided on the friction surface.
Well guys I bought the light weight flywheel from UAS today, and had a chat to John as always... They're real helpful over there I tell ya!
This one weighs in at 4.8kg.
Anyway, here are some photo's that I took of it. It'll be installed tomorrow with the daikin heavy duty clutch.
click thumbnails to open the photo in a larger window
I'll know the results tomorrow.... (fingers crossed ay)
wil..
Clutch and flywheel are in.
Torque loss - None that I can really feel. The car however picks up a lot nicer than it use to. It runs through the rev's significantly faster than before.
The clutch is rated as having a higher clamping force than before, yet the pedal feels "lighter" than it use to??? What's the go there.
The new clutch grabs a lot harder than the old. That much I'm sure of. But I'm just curious as to why the pedal feels lighter? I always heard that replacement clutches with higher clamping loads would be heavier in feel.
The extra clamping force is offset by changes in the diaphram pivot point - so the clutch feels lighter but you need more clutch travel to disengage.
I had a molly lightened flywheel on my RB20DET, not quite as nice looking as yours though. :D
It is true that it needs more rev's to get off the line but I did find it accelerated quicker.
It felt as the torque made from the motor wasn't absorbed in the heavy flywheel before accelerating the car, instead more of the torque generated by the motor was able to filter through to the rear wheels quicker and easier accelerating the car quicker.
It also felt as if it didn't bog down as much, boost felt a little more snappy.. :)
It was a nice little mod. :(
i got a 2.5kg lightened fly for my car worth $900 apparently... just waiting for the work to finish b4 i can test it out
Hmm you sure it weights 2.5kg??? If so it must be made of carbon kevlar or some other exotic material?
I have 4.8kg chromemolly and the engine revs upto redline alot quicker and i dont see any negative effects with one
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
