After receiveing a lot of questions and requests for power fc's in my APEXi AVCR GROUP BUY I have managed to organise a group buy with my supplier for the APEXi POWER FC ECU.
Here's the deal;
1 x Brand new Apexi power fc and commander including all Shipping, Duties and GST for $1220.
Please note - The power fc and hand controller is classified as an Automatic Controlling Apparatus - Tarrif Code 90328980 - therefore it is exempt of any customs duties.
MINIMUM BUYERS = 10.
AVAILABLE FOR:
Skyline......GTR......BNR32, BCNR33, BNR34.....RB26DETT
Skyline......GTS.......ECR33, ER34.........RB25DET
Silvia.........PS13, S14, S15.........SR20DET
180SX.......RPS13.......................SR20DET
All power fc's are covered by 12 month WARRANTY .
BUYERS LIST;
1/ DVSGTS..........BNR32..........RB26DETT
2/
3/
4/
5/
6/
7/
8/
9/
10/
As long as the minimum number of buyers is reached then this group buy will be successful. (Unlike previous group buys for power fc's that have failed due to supply issues)
As soon as all payments have been recieved, the units will be shipped immediately via EMS and will reach the buyers within 3-7 working days.
This is a genuine group buy which I am not profitting from at all.
Paul :(
nengun can do it for $1080.
wont work with auto.
the manual is outdated and incorrect model. here is the manual for powerfc you are selling http://www.apexi.co.jp/pro_apexi/electroni.../POWER%20FC.pdf
Gascan - sorry, unable to get the AP Engineering ones.
paulr33 - thanx for the link but it doesnt go to the manual and your right about power fc not being available for autos. I stuffed that bit up. :Oops:
If you guys would prefer to go through nengun then please do so. I have dealt with nengun before and I was happy with my purchase and buying experience.
But without this turning into another "nengun" thread I am offering a new power fc for a competitive price. (One of the best prices on the forum for a power fc.)
I will do my best to answer all questions promptly and ensure the speedy delivery of your items without any further costs or taxes.
Yeah I was gonna say it's not exactly a cheap price considering any joe blow can buy 1 from Nengun for $1,150 delivered.
Add 10% GST to the $1150
total landed cost is $1265
The group buy price includes GST total $1220 :)
Gee, looks like I'm the newest member of nissansilvia.com :P thanks to pinoi_boi_r33!!!
those prices are great!
LOL... naughty pinoi_boy!! :( read the rules.
ps. those are some nice prices over at the nissansilvia group buy :cheers:
Its all good!
I would rather that the members got a better deal. ( I know I would prefer it! ) But I would like to be able to get these cheaper for SAU members so you dont have to sell out and join up with NS.com... J/K :)
I am trying to get these cheaper for every one so keep an eye on this thread as I will hopefully be updating the prices shortly.
:P
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
