hi guys
i have the following 4 sale and need to get rid of tham asap as old laddy kicking up a stink
plz all parts need to go make me offers on parts
r32 gtr parts
bilstien h/a with 1000km old dobie sports 1 inch lower coild $600
bilstien h/a sus $500
std front and rear gtr 32 sway bars 200 pair
gtr steering colum with ignition and all covers and controlers $80
m's pod adaptors $100
steering rack $300
front wishbone setup with hubs $150
a/c under dash fan and heater box and a/c rad under dash $150
center console glove box $50
clutch power booster and master cylinder $130
brake power booster and master cylinder $180
rear calipers $100
pasenger side front drive shaft with both cvs $140
driver and pasenger side rear drive shaft with both cvs $320 pair
projector head ligts perf con $200
r32 gtst parts
bonet excelent con metelic black $100
left hand front pannel perf con met black $50
front bumper $50
front bumper suport bar $50
front lip motors 4 spoiler $130 pair
steerein colum all acc $80
std gtst compleat set of rims perf con $200
instamental cluster $50
all other dash bits and pieces and switches and controle moduals avalible just pm me
cheers
https://www.sau.com.au/forums/topic/63952-r32-parts-all-have-to-go/
hi mate,
I'm looking for the drivers side outer kick panel (the one that covers the ECU) and the same bit on the drivers side.
Do you have them?
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
