Chilli EAT OFF! - Tues Feb 15th 2005
  • Replies 139
Yes it was almost like there were 2 groups... One cool group, and one lame group... And then we split up, fought for a bit, made up, cuddled, but things just weren't the same...
Anyway, the point I'm trying to make is: I'm off to check the "Cool Forum"
Jokes, jokes... :P
any one got a spare wheel nut?????
one of ours mysteriously disapeared between arriving to eat chilli and leaving after eating too much chilli.
I hope you've got lock nuts on those mags?
I checked mine this morning when I got up to come to work. Not sure if any of them are loose, didn't feel like it.
This is the reason why I dont normally leave my car in carparks where people like that can get their grubby little paws on things.
  • 1 year later...
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
