Chilli EAT OFF! - Tues Feb 15th 2005
  • Replies 139
Yes it was almost like there were 2 groups... One cool group, and one lame group... And then we split up, fought for a bit, made up, cuddled, but things just weren't the same...
Anyway, the point I'm trying to make is: I'm off to check the "Cool Forum"
Jokes, jokes... :P
any one got a spare wheel nut?????
one of ours mysteriously disapeared between arriving to eat chilli and leaving after eating too much chilli.
I hope you've got lock nuts on those mags?
I checked mine this morning when I got up to come to work. Not sure if any of them are loose, didn't feel like it.
This is the reason why I dont normally leave my car in carparks where people like that can get their grubby little paws on things.
  • 1 year later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
