Hey,
i got a 1996 Daewoo Cielo and i want to add to the mods. I already have a talon Front spoiler and side skirts the rear will be completed in the next few months. And i have a T - Wing i picked up cheap out of the sunday times. What can i do to the engine to give it some more go, on a tight budget? :wassup:
Lets make this thing deadly!!!! :ghost:
https://www.sau.com.au/forums/topic/64080-how-to-get-faster-times/
First of all, Welcome to SAU :) especially NA section.
with your question, do some research on Korean based tune site... I doubt they are in english... :D
with faster time, simple answer is less weight :) so start loosing weight in your car or your self :P
Good luck.
btw Thanks for buying Korean car :P you are supporting my ppl. :P kinda :P
get an RB!!!
similar concepts apply to all cars - In my opinion skylines in particularly from 32 onwards, breathe alot better. I do not know about the Daewoo but in my camry, the
air filter is placed behind the battery in the engine bay, and the snorkel doesnt even
get any fresh cool air from the front. But with the funny angles and the positioning of
the airbox, it is simply impossible to install a pod filter.
The best you can do is probably change the panel airfilter and exhaust. There isnt too much
modification wise that you can do without spending mega bucks to get small power gains.
Try to make it breathe alot better, or like Pva_Glue says - just strip the car.
As to why your on an skylines forum - dunno - they may have a Daewoo forum with
others who may be able to help you better. But the concept is still quite relative.
or you can try to use nitrous.
If your serious about making it deadly and are on a tite budget, loose all ur seats mate.. LOL except the drivers side ofcourse, loose all the panels basically just have the necessities, and if u got a spare 1000 - 2000 in ur budget start with extractors , a 2.5" exhaust system and a new air filter
My mate told me i would get more power if i removed the air filter, so i removed it and went to clark rubber and got some flexible piping i screwed to the bottom of the front spoiler for a cold air intake. It makes a bit of a turbo noise now, yay! :P
I also went to the extreme of removing the headers and cutting it just before the cat. It gives it some extra watts and makes a nice noise, but its slightly too loud and too illegal so i will have to figure something out, in the mean time i will just enjoy what i have.
As for weight reduction is there anything else other than the seats i can remove???
so let me get this straight...
1. you removed your air filter and ran a pipe from down low right into your intake system
2. you cut your exhaust just before the cat
WTF!!!
obviously your taking the piss....
IF your not - WTF are you thinking?????
water/dust/dirt will be getting sucked into your motor for a start - you need some form of filtration ffs mate!!!!
and not only is it HIGHLY illegal to do what you did to your exhaust system (not only sound emissions but having no CAT - someone told me fine is well over 100 thousand dollars...) but you have now taken your horse power from 50HP to 20, nice work :P
the engine needs back pressure mate - you may as well get a PHAT 4" exhaust system and slap on this puppy if your going to cut it off.....same thing will happen - no back pressure = power loss
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
