Hey all!
Thinking about what to do to increase performance, I came across an ad for CO2 cooling systems in the latest Zoom magazine. In particular, the intercooler sprayer caught my eye.
Has anyone had experience with CO2 cooling before - does it make much of a performance gain? I remember in High Octane 2 they had a car using CO2 injection and the drop in inlet temps was pretty impressive.
PS: Serious qu aye? Ricers need not apply :headspin:
Cheers. ;)
https://www.sau.com.au/forums/topic/64305-co2-cooling/
are you sure it's co2? that's carbon dioxide and it's a biproduct of the combustion reaction of petrol. That'll mean there's less oxygen to burn, and therefore less power. Are you sure it's not no2 (liquid nitrogen).
Nah its a CO2 spray for sure, I remember reading about them.
Anyway an intercooler is a sealed item isnt it? It flows air, and allows air to cool the fins which the air is flowing thru??? So the co2 would just hit these fins making them cooler??? Yes no?
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1205469
you all remember 2 fast 2 furious ... remember at the start of the film, he pulls up in the r34, shooting flames out the back, and from the side of the front bar vents white vapour ... its co2
co2 is EXECLLENT at major cooling down, very quickly ... if you take a fire co2 extinguisher and open it onto a 4 pack of beer, it'll chill it down a LOT ...
imagine spraying co2 onto the intercooler fins ... it will cause the IC to cool down a LOT ...
but to do it, you'll be using a lot of co2, and co2 is not really very cheap ... you also have the danger of carring around a high pressure canister of gas ...
just my 2c
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1205494
Was that CO2? I always thought it was NAAAAAAAWWWWWWSSSSS(NOS) lol. I'm pretty sure it was NOS bro, when the white vapour shoots out its called 'NOS purge' or something along those lines. By the way CO2 can be used as an intercooler spray and in water injection where CO2 is shot directly before the throttle body, further cooling down inlet temps, i'd prefer Aquamist which uses normal water to a similar effect.
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1205576
in 2 fast 2 furious the R34 has NOS purge
Nitrous pressure should be kept consistent to obtain optimum performance. All NOS systems are designed to work best with a bottle pressure of 900-950 PSI. Pressure is determined by the amount of nitrous contained in the bottle and temperature. The chart below shows what happens to nitrous at various temperatures. Accordingly, it's a good idea to use an NOS bottle heater and/or blanket. Likewise, maintaining consistent line filling is important...which is why most racers use an NOS purge valve to release nitrous vapor from the feed line. This provides liquid nitrous to the inlet of the solenoid(s) for better consistency and repeatability.
The primary purpose of a purge valve is to release trapped air or gaseous nitrous from feed line(s). Helps to ensure consistent performances
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1205919
CO2 would only be used as a coolant for the intake charge, but only by cooling the components eg IC. Certainly if it was injected into the A/F mixture, the engine would run super rich because of the reduced amount of O2.
Some people have designed systems to carry dry ice (which is solid CO2) for cooling ICs, etc. But you would need to be wary because you might cool the IC so well that it ices up inside, partially blocking the IC.
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1205956
its a cryo cooling system that you guys are talking about, I am looking into getting one my self. They have a co2 bottle like nos but dont need a bottle warmer. Are not dangrouse to carry like nos because it is not combustable. What it does is sparys co2 at high pressure, which would come out of the bottle at something like -30 to -50.
They then use a smell sealled bulb in the intake manifold that they puch co2 through like an A/C system where the liquid co2 hits the bulb it expands and creats a massive temp drop.
They also do the same for the fuel line.
All the benifets of nos with out the hassels, and to fill a big bottle (e) of c02 it would cost about $60 and for a smalll nos (b,c) it will cost like 70.
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1205961
guys my mate has had the cryo cooling [aka Nitrogen cooling if u must know the specific]...
and from what ive seen he has never had a problem with cooling at any degree, even giving it hell down the tracks the entire day... only once or twice given it was 42 degree day and it was like 6-7 hours into giving the poor car a thrashing down the tracks to try and get his timse down did it have one lick of problems...
in all honesty, its a big ****ing cost but its well worth it, given u got good power that NEEDS that sort of cooling....
his car is pretty much a replica car that tommy kayra [how eva u spell his last name] made same sort of outputs but when it was brought here [some lucky prick baught it]... they removed most of the power mods but for some reason left the Nitrogen cooling system in it, hes only got 300-350 kw now cause hes having to spend some cash to get where he wants but yer...
just food for thought
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1206377
CO2 would be good for external cooling of the inlet charge, i.e the CO2 does not come in direct contact with the inlet charge. It is indeed NOS purge on that R34 in 2F2F but there is also CO2 intercooler spray cooling systems available on the market. The engineering company ARE has developed a special intercooler that holds a quantity of dry ice (frozen CO2) that is used to cool the charge. Im sure there are many other ways to enhance the effectiveness of an intercooler and I'm sure we will be seeing these on the market in the not too distant future.
https://www.sau.com.au/forums/topic/64305-co2-cooling/#findComment-1206564
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
