Which bolt on turbo will i need to make a
healthy250rwkw "BUT" with the most torque down low,
i figure i should run the more boost like 1.1bar to make it
rather than go external wich requires less psi but more
lag.
MY REASON: so on std boost my wife wont shit herself when it come on!!!
any help boys would be a appreciated
https://www.sau.com.au/forums/topic/64410-rb25-wnt-250rwkw-wich-turbo/
  • Replies 40
i think he has a gtr, which means that gtrs's would be laggy and produce lots more than 250 when they do come on boost.
if it is for a gtr, try gtss's 2530's or N1s, already they wont have much low down power(less than 4 grand) but go any bigger ie gtrs's and you wont have much power low down at all.
best bet for stockish low end would be hiflo the stock turbos and run more boost.
READ the post title "RB25 wnt 250rwkw WICH TURBO??" :slap:
:cheers:
GTRS is your best bet, you'll never do it with a 2530. 2835proS will do it easily at only around 1bar, torque down low wont be quite as good as the GTRS, but you'll have plenty of scope for more power. You might say 250rwkw is more than enough right now, but when you get it, you'll want 260. :cheers: Then 270. Then you'll be looking at cams and more boost for the magic 300!
Stock fuel system isn't good for anymore than 250rwkw (unless you're from perth :cheers: )
2 mates with gtsts run 2535's and both make around 235 nonshootout mode... or 250-255 in shootout mode... very responsive and very quick.
You think with Fuel pressure regulator and a good fuel pump the stock fuel system would be able to support 250rwKw? (and I'm from perth ehhehe :headspin: )
Im about to try a 2535 but dont have injectors at the moment, hope it'll get 250kw
will have results by end of month
well yeah if its rb25 then check out a hks2540 theyre a good well known mismatched turbo and is extra laggy but will flow more than 2530 in top end
or for around $2k get a gt30 with stock parts it should be laggy
but hang on a second, you said its for an rb25det, so do you mean
a) skyline gts with rb25det conversion
B) skyline gtst with stocker rb25det
not that it really matters
do you want
a) a mid power turbo that will hit 250rwkw
B) a mid/high power turbo with lots of lag and get 250 or a bit more
cos you've said you dont want low down torque as your wife will shit herself yet your looking at 2530, t51z etc which will have fairly good low down response (not laggy) and wont flow much top end (not enough for 250rwkw), sounds completely opposite to what you want? if you want laggy and flow enough for 250rwkw then i still stick with
hks 2540 (mismatched wheel/housing = laggy)
gt30 (on stock internals will be midish laggy, not much before 4k)
or speak to gcg in sydney and ask for a laggy turbo combination that will flow enough for 250rwkw on rb25det skyline maybe they can do a custom housing/wheel combo that it extra laggy for you and flow good for the same power level.
its for a gtS and the 2530 sounds torkie but if it blows i cant rebuild it thats y i like
trust turbos is there a greddy turbo thats like 2530 maybe T517Z or T518Z has
anyone had one of these on the old gts??   :P  :D
If I mis-read your post I apologise, but are you talking about hanging an aftermarket turbo off the side of a standard RB25DE. If this is the case I highly recommend against it, as to achieve that power you will need to lower the compression and change the internals. These turbos are fine on a std RB25DET but not on a std RB25DE.
Within the month you will be looking at a total rebuild, if not a new block if it decides to "kick a leg out of bed".
Sorry boyz i meant GTST not gts. :headspin:
i dont think 250 rwkw with response/torque is a
contradiction at all its possible i just havnt found tha right
combo yet but i will.
Im not keen to push more than 250 so small bolt ons are
perfect for me. trying to find trust trbos with t3 flange cant find any?? is there any? :P
its rb25t my mistake,
but just so u know high compresion na motors arent a
bad thing with turbos u get a lot more grunt down low u
spin any turbo round 1200rpm faster u just need to tune
ur ecu properly did it twice on a vl and a skyline and i ran
26psi threw the skyline wich i didnt need wiv t3/4 combo
and 2000rpm gave full boost an massive burnout torque.
tru story :P
so you want 250rwkw thats laggy?
well thats easy gt30 stock internals, aftermarket ecu
youll be on the stock injector limit once it cranks past 4000rpm and hits its boost peak
also will need to do the usual bolt on mods exhaust, cai intake, clutch, tyres, airflow meter (not 100% but will help) etc. things like cams, better tune, cai intake will decrease lag and u want more lag so dont do any of those
check out the rb25 turbo upgrade dyno post (search for it) and find the most laggy looking dyno graph. copy their mods and you shold be sweet. i suspect the hks2540 will be the most laggy or gt30 with stock internals, the gt30 is suited for a midly tweaked engine
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
