Hi all.
Was cruzin in the city on friday night to pickup a mate and i got pulled over by some D's , they said " we have pulled you over as the legality of the modifictaion done to your car" then i have to got to the rocks where they were all waiting.
This is the 1st time ive been pulled over in this car.
And 4 those of you that have seen my car you wioll fiund it funny that this is all they got me 4.
1. 19" wheels when tyre placard says 16" - Fine $120
2, Chasis has been modified for the intercooler piping - Fine $60
then the minors
1. Tints to dark
2. boost guage in a pillar above steering wheel
3. www.skylinesaustralia.com sticker on wind sheild (yes thats right a sticker can not block the wipers)
thats it.
Lucky i know a few people in the buisness ( if you know what i mean)
Cant they just leave us alone?
https://www.sau.com.au/forums/topic/64546-got-defected/
i doubt the p-plates would have much to do with it, i would have thought the imported skyline models would be enough for the police to pull over and check when defect stations are around
but considering all the recent events involving p-platers and all related stories i suppose you could be right
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1208944
hey dude, yeah i got done in the same area - down at the docks in the rocks (had my whinge sesh in the general forum :) )
luckily mines only fairly stock and they got me for pod filter (frantically trying to find an airbox to fit the r33)
some of the cops were real pricks acting talking like i'd killed someone, but luckily the chick that was looking after me wasn't too bad.
Anyway bad luck man, hope u get it all done in time,
Catch ya
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1211158
I drive around in a '97 series II with a standard Type-M kit, 18's with a GTR wing on the ass, I have not been picked up in it once yet, Its the huge GReddy stickers, 20 inch 'Bling bling stand-out-like-dogs-balls' chromes and ya 6inch exhaust tips that gets you pulled up. Cops are pricks, we all know that, why make yourself stand out to them, you dont need their attention cause it's bad news when you get it.
Getting defected is no big deal, it's not even about the fines, it's just the hassles of having to go back to get them cleared and shit.
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1211373
Wheel Track
As a general rule, it is recommended you only fit wheels and tyres that are listed on the tyre placard or in the
owner’s handbook. These have been tested and proved for your car.
Sometimes the range of wheels listed by the manufacturer may appear to be limited. While it is recommended
that you only fit these wheels, the RTA does not oppose the fitting of wheels outside the range providing they are
safe for the vehicle.
An important requirement for all replacement wheels is that the wheel track must not be increased by more than
25mm beyond the maximum specified by the vehicle manufacturer for that vehicle.
Wheel Width
Wheels up to 26mm wider than the largest optional wheel recommended by the vehicle manufacturer for the
vehicle can be fitted without the need to notify the RTA.
Wheel Diameter
The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter
wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel
and tyre combination specified for the vehicle.
i was wrong in my previous post its 15mm not 10mm :P
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1211664
Heres boys
had this discussion before
http://www.skylinesaustralia.com/forums/sh...ead.php?t=55039
by the way if you have any questions regarding Whats legal or illegal
ring the RTA Technical enquiries on 1300 137 302
FYI
I rang them yesterday and to my surprise i found out turbo timers are not illegal.
https://www.sau.com.au/forums/topic/64546-got-defected/#findComment-1212013
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
