Any1 know of a cheap place I can just get my front bar resprayed black? Im going to be re-fibreglassing it in the next week or 2 including priming and sanding, so I just need a spraypainter or home job with good results to give it a few coats of skyline black
Cheers
https://www.sau.com.au/forums/topic/64625-spraying-front-bar/
i respray my mates ae86 with a few mates. spraying isnt that hard of a job really, i would take GWP up on his offered and uses his place. i work at a spray-painter and i find that he doesnt like doing job where the person has pre the thing 1st (as most of the time the job is shitty and he has to redo it to get the spraying job looking half-alright)
im about to do my frontbar myself as it has heaps of fiber class on it (brough it back from life :))
i gots a compressor, spray gun and shed out here in barragup yas can come down an spray youself if ya gets da paint an s&%$
oh mite cost ya a brew or 2 for the old boy its his gear
Sounds good.. btw.. where the hell is barragup
yea also like to know how much roughly is the cost of spraying the front bar e.g. 400R, veilside etc. By the way mine is the wierd dark blue/green coloured line. Just thinking of also selling my stock s1 front bar, its two tone with the bottom half being grey in mint condition, no dents.
cheers
Guys, if you are thinking about doing it yourself, the most important thing are primer!
Without this don't bother. If the prime is nice and thick, with smooth sanding, than you only need, not so much of the actual colour. You have to sand the grains back, before you paint. Ok, now you have painted it. DO some more fine sanding before glossing it? 1000R paper.
Second most important thing is to put lots of gloss on it. Topcoat clear. So you can polish the thing later. And you have to give it few layers. 4 max. Coze buffing will wear it down.
The thing is a guys, if you sand the thing down, and put prime yourself, the painter will only cost you $80 bucks. That is very good considering the leaking spray scenarios at home.
Oh yeah, the painters have extractors on the roof, and much better equipment, like 6 to 12 hp painting machines with better flow ratios than the cheap home ones.
So if you want it looking good. ;) Well then :P
Any names of places that will do it for $80?
Any in our area?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
